93 Honda civic del sol H22 swapp and Turbo! (central ohio)
Just traded my family car for this off a member on here.....need cash for a 4dr ( not looking for trades unless you have a teg 4dr and cash or other import + cash)
Located in columbus ohio
93 Del Sol Si
Exterior:
Samba Green
Retrofit projector Headlights
Amber Corners (not picured)
OEM JDM EG Amber Side Markers (not installed)
Stock Otherwise
*Fair condition, got some rust in rear quarters (painted over with samba green touch up paint) Front fenders and hood have some dents due to previous owner sitting on them. Car still looks good in my opinion.
Interior:
Prosport Boost Gauge
Amber lit OEM Cluster
Grant Steering Wheel and Steering Hub
Pioneer Head Unit (top of the line when purchased)
Polk Audio 6 1/2s In All Four Corners
*Very clean interior, only flaw is the drivers seat has a tear in the right bolster and the door panel vinyl started wrinkling where your arm would rest but overall very clean.
Suspension/Brakes:
KYB GR-2s
Bomz Coilovers (Ebay, 450lb front 350lb rear)
Oem Front Sway Bar w/ Energy Suspension Bushings and Endlinks
Converted To Manual Steering Rack
Energy Suspension Upper Ball Joint And Tie Rod End Dust Boots
Brand New Lower Ball Joints
Brand New Front Wheel Bearings
EBC Crossdrilled and Slotted Rotors All the Way Around
EBC Green Stuff Pads Up Front
All Calipers Recently Rebuilt And Greased
Brand New Wheel Studs Up Front
Ebay Front Camber Kit
SPW Front and Rear Upper Strut Bars and Rear Lower Tie Bar
*Car rides and handles great with havin an h-series. A blast to drive.
Engine/Trans:
JDM H22A
JDM H22A Trans
Hasport Motor Mounts
Steel Braided Clutch Line
Ported Intake Manifold (secondary butterflies removed, Vtec pops like crazy, very loud)
DSM 450cc Injectors
New Intake Manifold Gasket
New Exhaust Manifold Gasket
B&M Fuel Pressure Regulator and Gauge
Competion 4-Puck Sprung Clutch
Fidanza 11lb Flywheel
NGK Plugs and Wires
New Passenger side Transmission Axle Seal
New Head Gasket
ARP Head Studs
Ebay Turbo Manifold
SSAutochrome Wastegate
Blitz Style BOV
2.5" Intercooler Piping
Big-*** Ebay Intercooler
3-ply "DIY" Couplers
2.5" Downpipe
Tuner Toys Oil Line Kit
Aftermarket Oil Pressure sending unit is plumbed ready for a gauge
* Car moved! Tuned on Crome @ 5psi. No traction till third, 2nd gear roll tires break loose when Vtec Engages. Trans works great except 5th gear has a problem staying in gear, pops out when you let off the gas. Clutch grabs hard. Engine was only on boost for a couple weeks.
needs turbo ( ebay one broke)
Pics> http://pittsburgh.craigslist.o....html
email me for pictures at mx6trickout@aol.com if not sold in the next couple days i will have a turbo on it and listed on ebay for alot more $
93 Del Sol Si
Exterior:
Samba Green
Stock Otherwise
Interior:
Suspension/Brakes:
KYB GR-2s
Engine/Trans:
JDM H22A
JDM H22A Trans
DSM 450cc Injectors
NGK Plugs and Wires
New Head Gasket
ARP Head Studs
Ebay Turbo Manifold
Blitz Style BOV
2.5" Downpipe
just got the car a week ago....it was on here
i will take $3300 cash by this saterday (moving and i dont want to take it) or i will put a turbo on it and it will be on ebay next week for $5k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 »</TD></TR><TR><TD CLASS="quote">price? what numbers did it put out?</TD></TR></TABLE>
Got the car from me... I believed it dyno'ed at 182 to the wheels all motor. I got the turbo tune of a member of h-t, claimed 260 at the wheels on 6psi.
bump for my old car!
Fibercation
Jun 19, 2008 04:46 AM
