JDM Crx nose cut vs USDM Crx nose cut
Old Jun 5, 2008 | 04:52 AM
blaak-crx's Avatar
Default JDM Crx nose cut vs USDM Crx nose cut
So a friend needs to replace part of the front chassis (from the fire wall to the front, excluding the firewall) of his USDM crx. We found a bare bone 1989 Crx JDM nose cut. We were wondering if anyone knows if they are the same. We want to put all USDM components.
1) We heard that the tranny engine support is not at the same spot (no problem that can be moved).
2) How about front & rear cross member anchor points?
3) Anything else that can be different.
Modified by blaak-crx at 5:59 AM 6/5/2008
Old Jun 5, 2008 | 08:28 AM
gator88's Avatar
Default Re: JDM Crx nose cut vs USDM Crx nose cut (blaak-crx)
I cant answer your question, but i do want to thank you for not taking that clip and trying to do a RHD swap. Not that I havent seen some really clean, nicely done ones with the firewall swap and all, I just dont understand all that hacking **** up when it is still a USDM car with RHD. thanks
Eric W
Jul 19, 2011 07:30 PM
bchap
Feb 27, 2010 09:17 AM
EF-Boy91
Oct 22, 2006 02:33 PM
ilovemyed8
Nov 5, 2005 05:12 PM
AIWFCIATR
28
Dec 28, 2004 12:21 AM
