Spoon Twin Block Caliper Dimensions...............
Old Jun 5, 2008 | 03:46 AM
Toy Civic's Avatar
Default Spoon Twin Block Caliper Dimensions...............
I plan on purchasing a set of Spoon twin blocks for my 1995 EJ1 with an ITR 5 lug suspension. I also plan on ordering a set of forged wheels from either JLine or Boze.
Both JLine and Boze state if I have a caliper upgrade that they would need the dimensions of the calipers to ensure that the wheels will clear with the +42mm offset I will be going with. They stated that many brake calipers have templates available.
Do Spoon calipers have templates available?
If not, then compared to factory ITR single piston calipers:
- How much wider are the Spoon versus the ITR calipers in relation to the transverse centerline looking from front to rear?
- How much more overhang is there of the Spoon versus ITR caliper from the hub center?
Old Jun 13, 2009 | 01:43 AM
No_Fear's Avatar
Default Re: Spoon Twin Block Caliper Dimensions...............
i dont know if this will help you :
Twin Block:
240mm x 95mm x 135mm
2.4 kg
Piston Size: 42.85 + 38.18
Monoblock:
250mm x 75mm x 148mm
2.6 kg
Piston Size: 40.46 + 36.12
jacki eg6
Jun 7, 2011 05:15 PM
Biffy_bud
Feb 27, 2007 05:37 PM
