personal best b16 bfg's and 60 trim
Old Jun 4, 2008 | 08:17 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default personal best b16 bfg's and 60 trim
well i went to the track for the first time this year and with the new car
95 integra, full weight minus rear seats and spare
b16 block:
eagle rods
cp pistons
b16 head:
aebs intake manifold
gsr t/b
rocket motorsports valvetrain
gsr cams
street port/valvejob
gsr transmission:
stock axles
competition clutch stage 4 sprung
ebay cast manifold
t3/04e 60 trim stage 5 exhaust
3"dp
3" exhaust
jrc intercooler
all runs were approximately at 15lbs (2nd 3rd 4th) according to my datalogging
225/50 15 bfg's on 00 gsr swirlies
neptune rtp tuned by john kerr of j-k-tuning.com at innovative motorworks in carlisle pa on a dynapak dyno dyno read 16 map said 15
60' 2.057
330 5.535
1/8 8.305
mph 90.89
1000 10.633
1/4 12.587
mph 113.55
let me know what you all think, it was my only clean run and i was low on gas so i quit for the night, was having issues with intercooler pipe blowing off in 4th gear on my other runs
im hoping to turn the boost up to around 19lbs on the dyno and get it to hold untill redline instead of it dropping off (didnt have time to get pwm working last time although i used it at the track)
Old Jun 4, 2008 | 09:56 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
simple and gets the job done
19psi like you said and some slicks and pray for 11.99
Old Jun 4, 2008 | 10:10 PM
johnls's Avatar
Default Re: (jdm_dc_fan)
nice setup good number
Old Jun 5, 2008 | 04:02 AM
nasteboyii's Avatar
Default Re: personal best b16 bfg's and 60 trim (EARLdaSQUIRREL)
I think thats pretty decent times, considering your car is heavy, i had a very similiar setup on my civic hatch eg, and went 1200s on 205 radials (of course my car is alot lighter) t3t4 e60, on 7 psi, and moved up to 225 radials and went 1180s, turned up boost, made some more power went 1157, (18 psi, prob 300hp)
500 hp went 1140s, (never made clean passes), and then 600hp, went 1140s all over the place and blew up
practice and times will come down
good luck
dan
Old Jun 5, 2008 | 05:33 AM
jmm96gsr's Avatar
Default Re: personal best b16 bfg's and 60 trim (nasteboyii)
Good times. I'm rocking the same ebay cast manifold w/ a Garrett T3/T04 60 trim. What track did you go to?
Old Jun 5, 2008 | 07:14 AM
Default Re: personal best b16 bfg's and 60 trim (jmm96gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmm96gsr &raquo;</TD></TR><TR><TD CLASS="quote">Good times. I'm rocking the same ebay cast manifold w/ a Garrett T3/T04 60 trim. What track did you go to?</TD></TR></TABLE>
i went to new york international
i have a feeling with some more seat time and adjustments to pwm i can get low 12's with how its set up right now, hoping to cut a 1.9 sixty also
Old Jun 5, 2008 | 07:38 AM
gringotegra's Avatar
You should be able to cut a 1.9 easily....your times are pretty good...
i put down 321whp and 204tq on a dynojet and both our 1/8 mile mph are close to being the same but yet i trap 2mph higher in the 1/4....strange...
Old Jun 5, 2008 | 07:43 AM
Default Re: personal best b16 bfg's and 60 trim (gringotegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringotegra &raquo;</TD></TR><TR><TD CLASS="quote">You should be able to cut a 1.9 easily....your times are pretty good...
i put down 321whp and 204tq on a dynojet and both our 1/8 mile mph are close to being the same but yet i trap 2mph higher in the 1/4....strange...</TD></TR></TABLE>
i wasn't getting the same boost that i had on the dyno (was on a manual boost controller for tuning and switched to pwm for the track) so like i said i was only getting about 14-15psi at the track
Old Jun 5, 2008 | 09:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">
i wasn't getting the same boost that i had on the dyno (was on a manual boost controller for tuning and switched to pwm for the track) so like i said i was only getting about 14-15psi at the track</TD></TR></TABLE>
ooo ok ok!
makes sence now!!
Good luck!!
EARLdaSQUIRREL
Jun 16, 2008 10:20 AM
flatblackhatch
May 3, 2008 04:31 PM
LDS
Dec 4, 2007 02:59 PM
EviL~CrX
Nov 15, 2007 11:32 AM
