Automatic Ecu in a 5 speed car??
I need a stock obd1 ecu for a ls integra. If it is an automatic ecu and i have a five speed will it matter? what will happen by putting a auto ecu in a 5 speed car? TIA
If you are handy with a soldering iron, it's a pretty simple process to change an auto ecu to manual. You can look it up over at pgmfi.org. It should just be a matter of cutting one jumper and soldering in another. For a P28 02D011F0-1500 board you need to remove RP17, and solder a jumper in place of RP18. It may be slightly different for other boards.
panaphobic
May 6, 2008 07:25 PM
panaphobic
May 6, 2008 11:48 AM
boostin4door
Aug 24, 2004 03:49 PM
