Air Bag Cover Removal
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
are you going to remove the cover and reinstall it? if you do, make sure you ditch the airbag computer too...less weight
There are 4 10mm nuts, not bolts you need to remove. 2 are easy, the ones that bolt the airbag to the underdash frame. The other two are way up on the inside of the top of the dash.. hard to reach have a long extension.. they're even harder to put back in. then pull the bag out from the top.
follie gatts
Mar 19, 2011 03:10 PM
BoostedGSRBubble
May 4, 2002 05:19 PM
j/k
