Performer X users..throttle cable issue
Old Jun 4, 2008 | 04:36 PM
00b18b's Avatar
Default Performer X users..throttle cable issue
Which throttle cable are you guys using? I got the ITR cable but there is still too much slack even when adjusted to the very end. any suggestions?
Old Jun 4, 2008 | 05:14 PM
IntegraType-R's Avatar
Default Re: Performer X users..throttle cable issue (00b18b)
...i had a d series cable with my itbs, i put my stock R one back on with no problems.. running a 70mm Professional TB and pX manifold.
Old Jun 4, 2008 | 05:20 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Performer X users..throttle cable issue (IntegraType-R)
Most guys just use a stock cable.
Old Jun 5, 2008 | 07:05 AM
RNbuilt's Avatar
only use the furthest bolt on the right, the ones holding the bracket onto the IM.
all you need is that single bolt on the right, make sure its tight, and youll have to bend the bracket that came with the manifold
Old Jun 5, 2008 | 11:23 AM
00b18b's Avatar
Default Re: (RNbuilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RNbuilt &raquo;</TD></TR><TR><TD CLASS="quote">only use the furthest bolt on the right, the ones holding the bracket onto the IM.
all you need is that single bolt on the right, make sure its tight, and youll have to bend the bracket that came with the manifold</TD></TR></TABLE>
Even with that i still have 2-3 inches of slack i need to get rid of.
Old Jun 5, 2008 | 01:22 PM
OMG B16's Avatar
Take a picture for us? Maybe something is on wrong? There shouldnt be that much slack.
Old Jun 5, 2008 | 09:37 PM
2000EK4's Avatar
Default Re: (OMG B16)
I use a B16a2 cable.Also had to bend the bracket a little.
I use a Skunk2 68 mm tb.
mouab18c1
20
Jul 9, 2013 11:36 PM
Crank
Nov 7, 2008 02:30 PM
skoodles2k6
May 9, 2008 07:23 PM
88 rex
Jul 9, 2005 07:33 PM
R6Boy69
13
Mar 2, 2004 11:09 AM
