Fuse with different Amp
Old Jun 4, 2008 | 03:42 PM
AdventurousDude's Avatar
Default Fuse with different Amp
Hi!
Recently the fuse for 'radio-cigarette lighter' of my car blew up when I was used a cell phone charger in the cigarette lighter. It probably blew up because there was another wire (a wire for woofer) somehow attached to the fuse-socket from outside. Also, I pushed and held my cell phone charger for a few seconds in the socket. I think the fuse got overheated then. So, what I have done now is I've put a 20A fuse in the fuse-socket that requires only a 15A fuse (meant for radio-cigarette lighter). I believe I can now easily use my woofer (which I think is not connected in a right way. But I'm fine with the way it is), radio and the cell-phone/laptop charger easily at the same time. I hope it doesn't create any problem with my chargers.
Kindly let me know if I did something wrong by doing this.
Thanks for your help!
p.s. The model of my car is Accord 97.
Regards
AdventurousDude
Old Jun 4, 2008 | 03:43 PM
TheMuffinMan's Avatar
He knows where you live!
Yeah, not good, rewire stuff correctly always.
What you did was an incredibly ghetto fix and will cause more trouble in the long run.
Old Jun 4, 2008 | 07:28 PM
propwdialogue's Avatar
Default Re: (TheMuffinMan)
Agreed. Double check and/or fix your woofer wiring. If a fuse keeps popping, it means that something is wrong and you're being protected from fire, not "time for a bigger fuse."
Old Jun 5, 2008 | 10:30 PM
Default Re: (propwdialogue)
Thanks for ur help guys! I'll definitely look into it..
CheddarPopcorn
Jun 30, 2009 10:53 AM
imadigitalgod
Audio / Security / Video
Jul 7, 2007 04:59 PM
EG9_808
Aug 29, 2006 01:57 PM
specv5150
Feb 23, 2004 05:26 AM
PatrickGSR94
Apr 6, 2003 05:46 PM
