82mm LS-VTEC - Am I heading in the right direction?
Just thought someone might have a similar setup that could let me know what I can expect in terms of approx WHP.
B16 PR3 Head (Bone Stock with adj. cam gears)
B18B1 Block (Rods Stock)
RS Machines 82mm pistons (12:1)
OEM TYPE R Header
GSR Trans
DIY CBR 954 throttle body setup (experimenting with stock injector location)
PR3 ECU
Getting it tuned when it's in.
I know there are a lot of people running LS-V's to compare to, but I couldn't find anyone running 82mm pistons. If you guys have any tips for me please let me know. I've done a swap before but this is my first build and I just wanted to see where I stand.
Thanks.
OEM TYPE R Header
GSR Trans
PR3 ECU
Thanks.
I am running a similar setup.
82mm with a gsr crank
b16 head with alot of milling
s2s2 cams
I ran consistant 13.3's with alot of issues and no dyno tuning.
With some cams you could have a 12 sec setup!
s2s2 cams
