crx not starting
I have a 89 crx and it will not start when i turn the key the radio comes on and all my lights work but will not start i checked the harness on the fuse box under dash and under hood but everthing seems to be good plz help
dude it can be too many things to list...
first of all does it rev at all? click once? machine gun click?
if it revs but doesnt turn over OR sounds like a machine gun click then a starter could be in mind.
slow rev could mean battery low charge.
single click could mean battery low charge or starter also.
fuel pump could be going out, i dunno you gotta say what its doin.
is it a straight D or did you swap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevew84 »</TD></TR><TR><TD CLASS="quote">dude it can be too many things to list...
is it a straight D or did you swap?</TD></TR></TABLE>...or check starter cable for looseness.
Run your hand up the clutch pedal arm, you will find a tab with a hole in it and it should have a rubber pad (in the hole). This is the cushion for the clutch interlock switch. If the pad is there you need to go on up and find the interlock switch and manually close and see if the engine will spin,I hope this helps.
SomeDude56
Aug 12, 2005 04:12 PM
