LS swap idle surging still
Old Jun 4, 2008 | 12:54 PM
95civic16's Avatar
Default LS swap idle surging still
so my 95 dx civic has a idle issue. i got the ls from hmo and ever since i put it in its had a idle issue. first i eliminated the fitv and now the fast idle surge has stopped now when i go to leave when its cold its cold idle is at 2.5 and then once its a little warmed up it will surge from 1.2 to 2.5 then once its warmed up it idles normal idk what to do now. any input would be appreciated.
Old Jun 4, 2008 | 08:16 PM
95civic16's Avatar
Default Re: LS swap idle surging still (95civic16)
Bump
Old Jun 5, 2008 | 05:19 AM
95civic16's Avatar
Bump NEED HELP GUYS
Old Jun 5, 2008 | 07:19 AM
SoHc94's Avatar
fix ur coolant stuff and bleed ur lines. put it all back the way it should be. then bleed yur lines make sure theres no air. that can cause an erratic idle.
BlackJacket
Dec 8, 2013 10:07 PM
b20bFourDoorCivicLX
Honda CR-V & Element
Oct 10, 2013 06:35 PM
WhiteTrashedDA9
May 2, 2013 08:40 AM
Eighty-Nyne
May 1, 2009 06:55 AM
