Noise over bumps from rear of '99 EX sedan.
Old Jun 4, 2008 | 10:51 AM
shortlid's Avatar
Default Noise over bumps from rear of '99 EX sedan.
Well my wife's '99 Ex sedan has 117,000 miles on it now. And for the last 5,000 miles when you go over a bump with the rear wheels it makes like a squeaking/bumping noise. Does it with the 15" alloys or the stock wheels with snow tires? Can I just lube the rear suspension bushings or is it likely the rear struts are shot? The rear end does not bounce or sway??
Old Jun 4, 2008 | 11:12 AM
sql_civic's Avatar
Default Re: Noise over bumps from rear of '99 EX sedan. (shortlid)
Do you have a sway bar?
I'd look into checking if the brackets are loose or if they need to be lubed.
Old Jun 4, 2008 | 11:14 AM
count me out's Avatar
* B A N N E D *
if its not bouncy, your struts are fine.
your problem is either your sway bar bushings or compliance bushings.
Old Jun 4, 2008 | 11:32 AM
shortlid's Avatar
Default Re: Noise over bumps from rear of '99 EX sedan. (count me out)
I will check under the car. Are the sway bar end links likely culprits. There were on the front of my '99 ACCORD EX sedan?? What and where are the compliance bushings?? I can just use silicone/bushing greese on them right?
Old Jun 4, 2008 | 12:25 PM
* B A N N E D *
compliance bushings are the largest bushings that are press fit into your trailing arms. they are impossible to replace without a press or the tool to press them out. you can try spraying them with some silicone lube or wd 40. best thing to do is look at the bushings and then decide if they need replacing.
Old Jun 4, 2008 | 12:43 PM
shortlid's Avatar
Got ya pressed into the trailing arms. I will soak them in Silicone spray WD40 eats rubber! See if that helps. Is they are all falling apart might swap them.
Modified by shortlid at 9:25 PM 6/4/2008
Old Jun 4, 2008 | 08:27 PM
shortlid's Avatar
Well just crawled under there and sprayed every bushing I can find. But I could not find a rear anti-sway bar did a '99 EX sedan come stock with it?? I always wondered why my '93 Toyota corolla DX station wagon handled better than the Civic it had sway bars front and back stock!
swordofdoom
Honda CR-V & Element
Sep 9, 2013 12:56 PM
EF'nA
Jul 29, 2008 07:24 PM
Mikes2000civicsi
Suspension & Brakes
Mar 27, 2008 10:17 PM
djmatix
May 20, 2007 02:19 PM
Josh10e
Sep 15, 2005 06:13 PM
