ABS light code 1 8 (high pressure system)
Old Jun 4, 2008 | 09:49 AM
alacard's Avatar
Default ABS light code 1 8 (high pressure system)
My friend is about to buy an integra that has this code for the abs light. (1 8 high pressure system). Any clues on how to diagnose the problem?
Thanks in advance
Old Jun 4, 2008 | 12:48 PM
alacard's Avatar
Default Re: ABS light code 1 8 (alacard)
No one knows how to fix this?
Old Jun 5, 2008 | 01:36 AM
alacard's Avatar
Old Jun 5, 2008 | 09:32 AM
spinimbus's Avatar
Check the relief valve at the top of the accumulator. It is the hex bolt on top of the cylindrical piece on the side of the ABS modular unit. If there is a leak you need to replace it.
Old Jun 5, 2008 | 10:45 AM
alacard's Avatar
Default Re: ABS light code 1 8 (spinimbus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spinimbus &raquo;</TD></TR><TR><TD CLASS="quote">Check the relief valve at the top of the accumulator. It is the hex bolt on top of the cylindrical piece on the side of the ABS modular unit. If there is a leak you need to replace it.</TD></TR></TABLE>
Alright, we'll try that out, thanks
srd....
Nov 12, 2019 06:58 PM
rockycat
Dec 8, 2014 07:37 AM
honda genome
Jul 2, 2007 05:08 PM
