need some help with mini me swap
Old Jun 4, 2008 | 09:24 AM
jdmsteve_01's Avatar
Default need some help with mini me swap
ok im doin a z6 mini me swap into my hatch but i still got tha dpfi harness, i have the z6 dizzy and ecu but i need to know what i have to do to my harness cause i asked my friend and he said i just need to modify the one i got and that i can hard wire the vtec. any body know or have a write up on what i need to do to my harness
*the injectors are obd0 so im not sure if i will need a resistor box.
Old Jun 4, 2008 | 09:40 AM
24TEN's Avatar
PHANTOM MENACE
Check in the FAQ at the top of the forum. I'd say MPFI conversion to start but I'm not sure on the specific way to wire it since you won't need the resistor box anymore. VTEC can be hardwired from the ECU. Your best bet is to check out RYWIRE for conversion harnesses. It'll make things mostly plug and play.
Old Jun 4, 2008 | 10:17 AM
yea i checked them out its just i have the z6 wiring harness and mine i just dont want to spend 300 when i could do it myself, ill check out FAQ
sirtimeless
Apr 6, 2011 08:08 AM
*i<3MyCiViC*
11
Aug 23, 2010 08:11 AM
ASO
Oct 23, 2009 03:08 PM
zach322
Dec 8, 2007 09:58 PM
