jdm B18C passed ref yesterday!!!
Old Jun 4, 2008 | 09:06 AM
gizzerhatch's Avatar
Default jdm B18C passed ref yesterday!!!
if you are attempting to get you car to pass you will need a stock GSR cat. it makes such a world of difference. it was my fourth time going and i finally passed. i feel great right now.
if you are going through this trouble here is somethings that you can try and should help a lot.
make sure everything is carb legal.
get a usdm p72 ecu
02 sensor- make sure its working properly
stock GSR cat.
and i ran a mix of 91 and 100 octane just to help the fuel burn for efficiently and get more heat to the cat.
and thats all i really had to do. it just took forever to do because no one really tells you what to do to pass a JDM GSR, so i thought i might let everyone know so you don't have to go through the trouble i did.
P.S. this motor in legendary for its high NO readout the max limit is 742 at the 15. i got mine down to 258!!!! my previous lowest score on the 15 was 1600+. on the 25 i got it down to 45 NO.
Old Jun 4, 2008 | 09:41 AM
eg:R's Avatar
Default Re: jdm B18C passed ref yesterday!!! (gizzerhatch)
just pass mine last month too. but mine was an ls swap
Old Jun 4, 2008 | 10:33 AM
eskerley's Avatar
Default Re: jdm B18C passed ref yesterday!!! (eg:R)
sweet! My turn next
Old Jun 4, 2008 | 11:05 AM
BlackoutVTi's Avatar
Default Re: jdm B18C passed ref yesterday!!! (eskerley)
That's real. I gotta BAR my D15B this summer sometime. Just went through all the hassle of getting smogged too.
Old Jun 4, 2008 | 10:05 PM
bump
Old Jun 4, 2008 | 10:11 PM
96civic_hb's Avatar
Man am I glad we don't have that **** in FL even though they are talking about adopting it...
Old Jun 4, 2008 | 10:28 PM
fistopher's Avatar
congrats! My experience was good, just do a clean job and make sure you got everything and its usually a breeze
Old Jun 5, 2008 | 01:37 PM
Default Re: jdm B18C passed ref yesterday!!! (fistopher)
bump for being victorious of stupid california smog regulations!!!
Old Jun 5, 2008 | 02:44 PM
raidacaipo's Avatar
Hey I have a jdm gsr too.. What about the manifold? can u use a stock jdm gsr manifold? Dont you need the Evap Purge solenoid? and if ur using a usdm p72 ecu then dont you need to wire the CFK sensor since the jdm gsr doesnt have it? tell me more details so I can pass too!!
Old Jun 5, 2008 | 04:20 PM
Mingo's Avatar
Default Re: jdm B18C passed ref yesterday!!! (raidacaipo)
congrats...i no that feeling too
Old Jun 5, 2008 | 05:56 PM
lluks_844's Avatar
Default Re: jdm B18C passed ref yesterday!!! (Mingo)
Yes you will need the CKF sensor to pass. You can either, swap a usdm OBD2 oil pump, or do the CKF trick.
Old Jun 5, 2008 | 06:05 PM
Ramirez428's Avatar
Default Re: jdm B18C passed ref yesterday!!! (lluks_844)
so what do you think helped you the most on getting the NO #'s Down? the mixture of octane?
Old Jun 5, 2008 | 06:35 PM
JeffBro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raidacaipo &raquo;</TD></TR><TR><TD CLASS="quote">Hey I have a jdm gsr too.. What about the manifold? can u use a stock jdm gsr manifold? Dont you need the Evap Purge solenoid? and if ur using a usdm p72 ecu then dont you need to wire the CFK sensor since the jdm gsr doesnt have it? tell me more details so I can pass too!!</TD></TR></TABLE>
I refed mine a few years back. I seem to remember that the Y pipe is different on the jdm gsr vs us so you need the us one, I think its longer and the collector is 2.5" on the jdm one. If your running the USDM ecu you have to have the cfk other wise it will throw a code. Make sure you got a stock cat like the op said.
Old Jun 5, 2008 | 07:56 PM
russlan44's Avatar
Default Re: jdm B18C passed ref yesterday!!! (JeffBro)
congrats, im hopping to get my h22 ref'd when im done with it
Old Jun 5, 2008 | 08:08 PM
OMGWTFBBQ!'s Avatar
Default Re: jdm B18C passed ref yesterday!!! (96civic_hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96civic_hb &raquo;</TD></TR><TR><TD CLASS="quote">Man am I glad we don't have that **** in FL even though they are talking about adopting it...</TD></TR></TABLE>
The BS florida emissions law is only going to affect cars made after 2009, we won't ever have to worry about it.
Old Jun 5, 2008 | 08:47 PM
raidacaipo's Avatar
Default Re: jdm B18C passed ref yesterday!!! (russlan44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russlan44 &raquo;</TD></TR><TR><TD CLASS="quote">congrats, im hopping to get my h22 ref'd when im done with it</TD></TR></TABLE>
I dont think you can swap an h22 into a civic...
Old Jun 5, 2008 | 08:49 PM
raidacaipo's Avatar
can someone lay down a really simple plan to follow if you have a jdm gsr motor obd2 and are trying to pass ref? I have a 97 civic hatch and I would like to know the real facts from people who actually passed.. for example gsr cat, change to usdm manifold or not? etc etc..
Old Jun 5, 2008 | 10:12 PM
i only wired up the knock sensor. i changed to a aem short ram intake for a 94-98 integra gsr carb #22-404 and i had the dc sport 4-1 ceramic coated header with a usdm p72. the thing that makes the most difference is make sure your 02 sensor is working properly and seriously just get a STOCK GSR CAT. the cat is a special 3 way cat that is specifically designed for that motor and to bring your NO dramatically down. do all that and for an extra boost run an even mixture of 100 and 91 octane and you should be happy with your results. make sure your timing is to spec also.
Old Jun 5, 2008 | 10:15 PM
stock gsr cat helps the most of all. my NO went from 2400+ down to 258 on the 15mph the max is i believe 742.
Old Jun 5, 2008 | 11:20 PM
raidacaipo's Avatar
SO everything else I can keep stock? like the stock jdm gsr manifold, the stock jdm gsr header 2.50 collector?? did you have an EVAP purge solenoid on your manifold and is it a stock jdm manifold? also did you have to wire the crank position sensor?? because the jdm p72 ecu doesnt look for that but the usdm DOES including the evap purge solenoid.
Old Jun 5, 2008 | 11:29 PM
i used my stock jdm intake manifold. i believe you can use the stock jdm header. but id change the header out and save like 30 pounds with an aftermarket header. that cast **** weighs a **** load. yes i do have the evap purge solenoid but its not wired up. you dont need it wired up. and as for the crank position sensor i dont remember having to wire it up i used my stock D16A (Z6) wiring harness. i just had to run the knock sensor and if i want to do the evap purge id have to wire it up.
Old Jun 6, 2008 | 08:08 PM
bump!
Old Jun 6, 2008 | 11:39 PM
bump!
Old Jun 12, 2008 | 03:47 PM
bahhhhummmmppppp!!!!
Old Jun 12, 2008 | 10:17 PM
raidacaipo's Avatar
hey how many wires do you have hooked up on your IAB solenoid? its a 2 piece plug but Im not sure whether or not it uses 2 wires or just 1 like the knock sensor wire.. I know for sure that one of the wire colors are pink/blue am I correct? is there a second wire on the plug? or just one?
