how many people run konis with springs verse full coilover systems?
Old Jun 4, 2008 | 08:53 AM
nahonda04's Avatar
Surje.motorsports
Default how many people run konis with springs verse full coilover systems?
on the dc5, is there any benefit from running one over the other?
Old Jun 4, 2008 | 09:54 AM
Todd00's Avatar
I said I don't want a title!
Default Re: how many people run konis with springs verse full coilover systems? (nahonda04)
Not as many that should be, especially on daily drivers.
People see 'coilover' and they think it is automatically better. What makes a car handle well starts with a quality shock, and sadly none of the sub $1000 fully adjustable coilovers (for Ep3/RSX applications) have what I'd even remotely call a good shock.
Old Jun 4, 2008 | 10:14 AM
rawNArsxS's Avatar
Default Re: how many people run konis with springs verse full coilover systems? (Todd00)
you sayin koni is a good shock for us? good thing thats on my summer to do list
Old Jun 4, 2008 | 11:35 AM
Todd00's Avatar
Default Re: how many people run konis with springs verse full coilover systems? (rawNArsxS)
Unfortunately there are not a lot of good shock options for the chassis, but the Koni yellow is certainly one of the better/best ones.
Old Jun 4, 2008 | 11:54 AM
nahonda04's Avatar
Surje.motorsports
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Unfortunately there are not a lot of good shock options for the chassis, but the Koni yellow is certainly one of the better/best ones.</TD></TR></TABLE>
they would run better than a coilover system then. i was never a huge fan of coilover systems, i would like to run the spring i have on the car now, H&R, with the yellow koni
Modified by nahonda04 at 12:59 PM 6/4/2008
Modified by nahonda04 at 1:00 PM 6/4/2008
Old Jun 4, 2008 | 12:04 PM
Jus4U2NV's Avatar
I run the Koni Yellow's with Eibach Springs on my 06' DC5. Ride is just fine, obviously it's a little bit rougher than stock even on the softest setting. But no complaints here with the setup I have.
Old Jun 4, 2008 | 12:54 PM
rawNArsxS's Avatar
Default Re: how many people run konis with springs verse full coilover systems? (Jus4U2NV)
which eibach spring? i was gonna do koni with eibach pros
Old Jun 4, 2008 | 02:42 PM
Jus4U2NV's Avatar
Opps my bad, they are the pros. I like the ride, don't think I will be changing to anything else anytime soon. It does sit really low with the A-Spec kit (probably an inch or so off the ground), but I have had no problem with hitting bottom. from me on the setup.
Old Jun 4, 2008 | 02:46 PM
nahonda04's Avatar
Surje.motorsports
i don't need anything that low, lol, but thanks for the input. i will more than likely end up getting the yellow koni
Old Jun 4, 2008 | 03:27 PM
Jus4U2NV's Avatar
Good luck with the setup
Old Jun 4, 2008 | 03:43 PM
nahonda04's Avatar
Surje.motorsports
thnx, it will be fun i am sure.
Old Jun 4, 2008 | 03:53 PM
rawNArsxS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jus4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">Opps my bad, they are the pros. I like the ride, don't think I will be changing to anything else anytime soon. It does sit really low with the A-Spec kit (probably an inch or so off the ground), but I have had no problem with hitting bottom. from me on the setup.</TD></TR></TABLE>
can you post a picture of your car? as i said im gonna be running the same setup and i also have the aspec kit and love to see how it looks
Old Jun 4, 2008 | 05:17 PM
blackk20dc5's Avatar
quick question cuz ur talking about suspension
i was going to get some new springs
if i get the konis yellow, can i just put those in with the spring and lleave everything else
or do i need to upgrade other parts or buy additional parts
Old Jun 6, 2008 | 06:41 PM
square_1's Avatar
Default Re: how many people run konis with springs verse full coilover systems? (blackk20dc5)
From what I've seen and what I have heard talking to people you'd be better off going with a good set of shocks (koni yellows) with good springs than to just buy 1000 dollar tein or whatever coilovers...
How often are you really going to raise or lower your car? Keeping in mind that you need an alignment whenever you do so...
I'm putting my konis on my EP3 and I can't wait to see what it is going to be like. I expect nothing short of awesome though!
Old Jun 7, 2008 | 12:51 AM
concept11253's Avatar
I have koni yellows on ground controls. Honestly this setup was bomb but the koni's blow out pretty easily. They definitely need to be revalved if your going to lower more then an 1.5" Koni's and springs will definitely out handle the cheaper coilovers like Megan, progress, and Ksport. Pretty sure Tein and Apexi have them more then beat though.
Drop is less then a finger all the way around
Old Jun 8, 2008 | 10:46 AM
Jus4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rawNArsxS &raquo;</TD></TR><TR><TD CLASS="quote">
can you post a picture of your car? as i said im gonna be running the same setup and i also have the aspec kit and love to see how it looks</TD></TR></TABLE>
I can get a post of the car later today
Old Jun 8, 2008 | 11:26 AM
rawNArsxS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by concept11253 &raquo;</TD></TR><TR><TD CLASS="quote">I have koni yellows on ground controls. Honestly this setup was bomb but the koni's blow out pretty easily. They definitely need to be revalved if your going to lower more then an 1.5" Koni's and springs will definitely out handle the cheaper coilovers like Megan, progress, and Ksport. Pretty sure Tein and Apexi have them more then beat though.
car looks good bro
I can get a post of the car later today </TD></TR></TABLE>
sweet thanks man i appreciate it
Old Jun 10, 2008 | 01:02 AM
Jus4U2NV's Avatar
Sorry it took so long, if you need more pics I can post em.
Old Jun 10, 2008 | 04:20 AM
rawNArsxS's Avatar
wow thats the konis with eibach prokit springs??? i didnt think it would be that low. looks good bro
Old Jun 10, 2008 | 01:57 PM
nahonda04's Avatar
Surje.motorsports
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jus4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">Sorry it took so long, if you need more pics I can post em.
thats how mine sits now without the koni's. lol. still need to get them thou
Old Jun 10, 2008 | 05:43 PM
Jus4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rawNArsxS &raquo;</TD></TR><TR><TD CLASS="quote">wow thats the konis with eibach prokit springs??? i didnt think it would be that low. looks good bro</TD></TR></TABLE>
Yea one of the main reasons obviously is the A-spec kit. Thanks for the positive feedback
Old Jun 10, 2008 | 06:10 PM
rawNArsxS's Avatar
dude i have the aspec kit too and it def doesnt hang low at all idk what your talking about. your car doesnt look that low to the ground...its the drop, the wheel well gap, that looks pretty much perfect. i cant wait to get mine
Old Jun 11, 2008 | 08:05 AM
thetunersource's Avatar
nice!
Old Jun 11, 2008 | 11:02 AM
Jus4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rawNArsxS &raquo;</TD></TR><TR><TD CLASS="quote">dude i have the aspec kit too and it def doesnt hang low at all idk what your talking about. your car doesnt look that low to the ground...its the drop, the wheel well gap, that looks pretty much perfect. i cant wait to get mine</TD></TR></TABLE>
Look forward to seeing it, post pics soon
Old Jun 11, 2008 | 11:25 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (concept11253)
Despite what a few people in this thread have said Progress coilovers are thought to be the best "economy" coilover available. There are no "adjustments" other than ride height and the shock is matched to the spring rates.
