fuel pump
anyone upgraded there fuel pump? i need to upgrade my pump but can't find one that will fit. i tried the wolbro 255 but it's too long and would not fit in the housing. i thought about using zex booster, but returnless system so i cant use it. any help appreciated. oh, 2003 accord lx 2.4l
i installed a turbo kit, skunk2 stage 1 cams, rc 550 injectors and golden eagle fuel rail. tried to install the pump but will not fit. it will run ok first but when i stop at the light it stalls. i found out today that i may have to change my fuel system.(not happening)
Are you on gen7? There is a walboro 255 pump you can replace it with, I think you have to modify it a little bit though, but it will work. What are you tuning with?
yep i'm on gen7 and i'm using emanage.what fuel pump, injectors and rail are you using on your boosted accord? if you don't mind me asking. i am about to put back on the stock rail and see if it makes any difference. if not i'm going back to stock.
turbolsvtecej1
Dec 7, 2012 09:27 PM
