FS: LS/VTEC Bottom End *CHEAP*
Old Jun 4, 2008 | 07:21 AM
ieatrice's Avatar
Default FS: LS/VTEC Bottom End *CHEAP*
B18B1 BLOCK W/ MAIN CAPS
- 81.5MM BORE/HONE/HOT-TANKED/RE-SURFACED - $300
- MICROPOLISHED/BALANCED CRANK - $100
- LS OIL PAN
- LS RODS
THE GOODS
- 81.5 PR3 PISTONS W/ RINGS & WRIST PINS
- ACL MAIN/ROD BEARINGS & THRUST WASHERS
- ARP HEAD STUDS (GSR/ITR)
- ARP ROD BOLTS (LS)
- FULL RACE LS/VTEC CONVERSION KIT
- GOLDEN EAGLE LS/VTEC DOWEL PINS
- ITR OIL PUMP
- ITR WATER PUMP
- ITR TIMING BELT
EVERYTHING IS BRAND NEW AND STILL IN ORGINAL PACKAGING! FIND A HEAD OR RE-USE YOUR'S AND YOU HAVE A BAD *** BOTTOM END!
$600 TAKES EVERYTHING TONIGHT
ieatrice
Jun 4, 2008 08:12 AM
ieatrice
Apr 26, 2008 08:53 AM
Mr_Moos
Northwest (Sales)
Mar 4, 2008 08:57 AM
93slmdcvcsi
May 26, 2006 02:08 AM
Vardoulika
May 2, 2005 10:03 PM
