My First N/A Build......
B18A Block
Stock Crank Micropolished and balanced
B16 Head
Wiseco Pistons 82mm 12.5:1
Carrillo Pro A Rods
Moroso Oil Pan
ARP B16 Headstuds
Supertech Springs
Buddy Club P1 Valves
Buddy Club P1 Cam Gears
Buddy Club Spec V Cams
Skunk 2 Cam Seal
Toda GSR Timing Belt
Fidanza Flywheel
CTR N1 Crank Pully
Hondata Intake Manifold Gasket
Golden Eagle Main Girdle w/ ARP mains
Golden Eagle Block Guard
cometic head gasket
ACL Race Bearing
Trying to figure out what intake, throttle body and header to run
Modified by sto4gcivic at 7:47 AM 6/4/2008
B16 Head
Carrillo Pro A Rods
Moroso Oil Pan
ARP B16 Headstuds
Supertech Springs
Skunk 2 Cam Seal
Fidanza Flywheel
CTR N1 Crank Pully
cometic head gasket
ACL Race Bearing
Save yourself the money from buying a new TB and buy a Sk2 manifold instead. If you really want to go bigger on a TB, which nets minimal gains, bore out your stocker, if you have one, and port-match it to the manifold.
TurboR1391
Sep 8, 2006 07:08 AM
