Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
EGR Insufficiant air flow Code 401
Old Jun 4, 2008 | 06:00 AM
Hondatech007's Avatar
Default EGR Insufficiant air flow Code 401
Hey All,
I have a CEL on with the code of 401 EGR Insufficiant air flow. I swapped out the EGR vale and cleaned the ports with carb cleaner and cleared the code, but no luck the CEL came back with the same code. anyone?
Old Jun 4, 2008 | 08:20 AM
oddmut's Avatar
Default Re: EGR Insufficiant air flow Code 401 (Hondatech007)
I'm not too experienced with this but I'd check in front of it and after it to see if there is anything else that needs cleaning.
Old Jun 4, 2008 | 10:16 AM
Curiouz_G's Avatar
what type of gas do you use and what spark plugs are you using?
Old Jun 4, 2008 | 02:32 PM
skipbarber's Avatar
this seems to be a common problem with these cars. good thing i dont have EGR.. carb cleaner alone wont do the job. you gotta spray it down with carb cleaner and use a pipe cleaner to really break loose any carbon build up. that or pressurized air, but a brush always works best.
em12nv
34
Jan 21, 2008 02:26 PM
420Accord
Sep 5, 2006 12:47 PM
iluznxpnoi
Mar 24, 2002 06:46 PM
