I have a Question about My Recaro Srd's Seats?
Just put an SRD in my '90 Hatch this spring. They make an adapter plate that mounts between the seat and the seat rails. You have to use the seat rails from your stock seat. They have to be cut off the stock seat and welded on to the adapter plate. It was a bigger project than I cared to take on, so I had a shop do it along with installing a harness. It took them a few hours, but it was worth the extra money to have it done right the first time. Hope this helps.
Does Recaro make rails for my 1991 honda civic hacyhback si.
Can i take off my stock rails and mount them on the Srds?
I mounted Mugen seats into my car using Sparco rails. Ive also had SRD's in there too. Sparco rails should suit you fine. You need the sliders and base though.
Recaro makes rail for your car to work with the USDM seat. I dont know about the JDM seats. Looks like Marty would know best though since he had them in there
As I said above, Recaro doesn't make rails for the car, they make an adapter plate that mounts to the stock rails. Also, as posted above, you may also want to check with Wedge Engineering.
trojan9x
12
May 25, 2005 07:26 AM
