c313 connector where wires go ?
on the connector that is on the driver side by the resistor box the c313 connector ????
http://i281.photobucket.com/al...1.jpg
theres a pic i have two wires hanging from the previous owner hacking into it im throwing codes 10,6 , and nine 9 anyone have any diagrams or have any idea where the wires run
your car may be an 88 Si, but that engine harness is not from an 88 Si - round 8-wire connectors were on 89-91 - the 88 connector is a square 6-wire and looks like this:
the reason the 89-91 had 2 extra wires was for the Fast Idle Control Valve which the 88 doesn't have - the black/yellow and blue wires are for the FICV - there are no wires in the 88 chassis harness to connect these wires to - for the car to run, you don't need the FICV - the codes you have aren't related to that connector - the wires for the sensors that are throwing codes are in the connectors on the passenger side - make sure all of the wire colors match on both sides of those connectors
i was reading in the manual that 88s and later have a eacv, on the back of the intake with the same color wires.black and yellow and the blue/yellow one said that the black and yellow went to fuse #14 and the other one went to the ecu to a11, maybe this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtmoney2002 »</TD></TR><TR><TD CLASS="quote">i was reading in the manual that 88s and later have a eacv, on the back of the intake with the same color wires.black and yellow and the blue/yellow one said that the black and yellow went to fuse #14 and the other one went to the ecu to a11, maybe this?</TD></TR></TABLE>the EACV has black/yellow and blue/yellow wires - the FICV has black/yellow and solid blue (not blue/yellow) - the black/yellow for the EACV is in ithe connector on the passenger side, not in the connector on the driver's side - from your picture, the blue/yellow appears to be connected - these have nothing to do with your codes - the wiring for all of the sensors giving you codes 6, 9 and 10 are in the passenger side connectors - code 10 is for TA (or IAT) intake air temp sensor which is located on the driver's side of the intake manifold - has 2-wire connector with red/yellow and green/white wires - code 6 is for the coolant temp sensor for the ECU which is located on the end of the head below the distributor - has 2-wire connector with red/white and green/white wires - code 9 is for the cylinder sensor which is in the distributor on SOHC engines and on the end of the exhaust camshaft on DOHC ZC engines - 2-wires run to the cylinder sensor from the ECU - they are blue/yellow from ECU pin C2 and blue/green from ECU pin C1
u need to get the electrical service manual for the car and sort through your harness tracing all the wires and everything. Time to get real familiar with your car.
Janos
Janos
Yep go to this link,
http://www.helminc.com/helm/Re...B4NN3
If that doesn't work, just go to this and fill in the info, http://www.helminc.com
U want the electrical troubleshooting manual.
Janos
Janos
PA MATT
Oct 27, 2005 03:04 PM
gocivicgo
May 16, 2003 01:45 PM
