need help installing coilovers on my crx
Old Jun 3, 2008 | 05:50 PM
crxhondata's Avatar
Default need help installing coilovers on my crx
i dont know where all those rings go here some pic how i think is go please correct me if is rown
Old Jun 3, 2008 | 08:31 PM
Khmi's Avatar
Default Re: need help installing coilovers on my crx (crxhondata)
The ring goes between the metal sleeve and the shock, it keeps the sleeve from moving...I used like 3 of them on each. Use the biggest one possible.
Old Jun 4, 2008 | 03:48 AM
crxhondata's Avatar
Default Re: need help installing coilovers on my crx (Khmi)
what about the the other rings where they go
Old Jun 4, 2008 | 08:21 AM
MyHotsh's Avatar
Your going to have rings left over.(little rings)
Find the ring that keeps the sleeve tight on the strut and use 2 of the same size on each strut. You should be good after that.
Old Jun 4, 2008 | 08:33 AM
nickrps's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhondata &raquo;</TD></TR><TR><TD CLASS="quote">what about the the other rings where they go</TD></TR></TABLE>
I had a ton of rings left over...not really needed. But, I promptly took the cruddy coilovers off because I used them with tokico illuminas which wouldn't let the coil over sit down in the perch...thus not slamming the car enough
Just an FYI if you have tokicos.
Old Jun 4, 2008 | 09:37 AM
crxhondata's Avatar
Default Re: need help installing coilovers on my crx (MyHotsh)
thanks for your help is really works
Old Jun 4, 2008 | 10:50 AM
nsxmatt's Avatar
They are no name Ebay coilovers that are meant to fit about 20 different models, so they send a bunch of rings to fit different struts. Chances are you will pull the coils off before too long when the springs sag and fail.
Old Jun 4, 2008 | 10:57 AM
crxhondata's Avatar
Default Re: need help installing coilovers on my crx (nsxmatt)
yeah this are ebay but i buy from honda civic 03 i try to make it fit i dont know yeah if is going to work on my crx i want to try
98Luder
17
Dec 18, 2012 02:07 AM
Balmoral
Oct 29, 2008 08:08 PM
civic4dizoor
Suspension & Brakes
May 11, 2007 08:02 AM
drewjesterjcc
Aug 9, 2006 02:16 PM
RAWB
Apr 3, 2004 12:45 PM
