Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Will 13in rota RB fit our civics
Old Jun 3, 2008 | 04:06 PM
civic_auto_x's Avatar
Default NEED HELP QUICK!!!!!! 13in rota RB fit our civics
ok guys and girls need some help and quick so if any of you have some information it would be great. first thing is i am an big growing autocrosser and i am trying to get some 13in wheels for my civic i know that the kiezer wheels well fit have tested them but hard to find for a good price then i found the rota RBs which i can get for about 200 for two and i need to know if they well fit over your brakes oem brakes at that so any information would be great thanks guys.
Old Jun 3, 2008 | 04:09 PM
kenbo21's Avatar
Default Re: NEED HELP QUICK!!!!!! 13in rota RB fit our civics (civic_auto_x)
well what year civic b/c the 01-05 civic's come with stock 14in rims and 15in rims on the ex...So if you have that year civic than you should be good with anything.
I have the Motige FF7 and they are 18in and fit with no problem..So personally you can fit those rims but you should look at going bigger..the 18in rims I have still have a lot of clearence..you could prob fit 19's if you really wanted to but anywere from
13-19 In rims would be fine
Old Jun 3, 2008 | 05:54 PM
ATLEM2's Avatar
pics of 13's on the vehicle? The 13in steelies I had wouldn't even clear my caliper.
Old Jun 3, 2008 | 06:24 PM
ok for one thing going bigger is not the answer i am an auto cross racer i need the smaller wheels for the gear ratio and less rotational weight. as well as i can get some massive rubber on the 13 that does not cost an arm and leg.
o and the car is an lx so it came with 14s on it and i know i can find it i just need a little help
Modified by civic_auto_x at 7:43 PM 6/3/2008
Old Jun 3, 2008 | 07:14 PM
toyomatt84's Avatar
Sanji
Default FV-QR
I have a feeling 13" wheels will not clear your 10" front rotors. Especially with the caliper attached to the knuckle.
Old Jun 3, 2008 | 07:25 PM
00falcon's Avatar
Default Re: (civic_auto_x)
14inch tires are pretty cheap... you can just stick with those...
Old Jun 4, 2008 | 02:35 PM
skipbarber's Avatar
^but he doesnt want to because they're steelies. the VX wheels aren't. but i sincerely doubt you'll clear the caliper.
Old Jun 4, 2008 | 08:58 PM
ShagNastyEK9's Avatar
13x7.5" lenso vpd's will clear integra brakes, and aluminum wheels generally have a good bit more inner clearance for brakes than any steel wheel. I know i have seen 13x8 rota rb's on a civic before, so i doubt it would be a problem
Old Jun 4, 2008 | 09:01 PM
also, 14" tires arent much more than 13", and the team dynamics 14x7's are pretty cheap, so you should consider that route
Old Jun 5, 2008 | 02:25 PM
Default Re: (ShagNastyEK9)
well i understand were all of you guys are coming from the thing is that i want the gear ratio that the 13s will give i need it so that my car well be faster were the 14s are not going to help as much as the 13s well.
Old Jun 5, 2008 | 02:58 PM
i do totally understand what you are getting at. I have done a ton of auto-x, and road racing. I dont know what tire you are looking to use, or what size, but let me know, the is a good chance you could go to a 14" wheel that is just as light or maybe a very slight amount heavier, and a tire with the same or a hair bit more overall diameter...... most competition 13" and 14" tires range from low 21" to low 23" diameters, so it is pretty easy to get something close in each size. I think going with a 14" will be easier with little or no more expense
Old Jul 15, 2008 | 12:38 PM
EGbeater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShagNastyEK9 &raquo;</TD></TR><TR><TD CLASS="quote">i do totally understand what you are getting at. I have done a ton of auto-x, and road racing. I dont know what tire you are looking to use, or what size, but let me know, the is a good chance you could go to a 14" wheel that is just as light or maybe a very slight amount heavier, and a tire with the same or a hair bit more overall diameter...... most competition 13" and 14" tires range from low 21" to low 23" diameters, so it is pretty easy to get something close in each size. I think going with a 14" will be easier with little or no more expense</TD></TR></TABLE>
Yes, but to use the new Hoosier 255/40-13 tire, you'd need a 13" rim... and that's significantly <U>wider</U> than anything available in a 14" size. Hoosier's biggest 14" A6/R6 tire is only a 225/50-14:
http://sccaforums.com/forums/thread/291943.aspx
https://www.hoosiertire.com/speccat.pdf <U></U>
Old Jul 16, 2008 | 07:36 PM
sloem2's Avatar
Default Re: (EGbeater)
yea but why
Old Jul 17, 2008 | 05:08 AM
EGbeater's Avatar
Default Re: (sloem2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloem2 &raquo;</TD></TR><TR><TD CLASS="quote">yea but why</TD></TR></TABLE>
Um... because 255 section width is greater than 225?? And a race tire that's 30 mm wider means more grip and more speed?
kawaihaeeg6
17
Jan 17, 2012 01:13 PM
retro1
Acura TSX
Mar 11, 2010 02:05 AM
xpwex
Jul 20, 2009 01:33 PM
1991hb
Classic Hondas
Jul 21, 2007 06:26 PM
Burrito
Aug 6, 2003 01:04 PM
