IATV cleaned/tightened - Loose already
Alright, so I took my IATV out and cleaned it and it was completely unthreaded from the threads. I re-threaded it down and my idle was instantly lowered back to normal. Now, after about 1-2 months it's beginning to idle weird. My question is, when I open it up again, can I just tighten the IATV all the way down until it's completely tight? Or what should I do.
Thanks.
Thanks.
Yeah. I took it apart in hopes of finding the un threaded plunger piece, but it was still in there very snug. Cleaned it and put it back in, still having the idle problem. Any other ideas? If this helps, the other day my power steering line starting leaking so I took one from a 95 Accord that the line was braised(sp?) and fixed the problem. Well there was fluid ALL over the engine bay and hood so I went to the car wash and sprayed some engine degreaser and then washed it off. Just thinking maybe this caused a problem?
I'm also reading my Chilton's book to see what vaccum leak it could be.
Any thoughts/other things to look at?
