82mm itr build
Old Jun 3, 2008 | 12:38 PM
c5stunna's Avatar
Default 82mm itr build
im building a 82mm itr motor
does anyone know were to get some good pistons with a c/r of around 11.5?
and also were i can get a headgasket for the 82mm bore?
any other suggestions on the build?
thankss
Old Jun 3, 2008 | 12:52 PM
all-mtr-teg's Avatar
Default Re: 82mm itr build (c5stunna)
P30 pistons will work nice, and an OEM head gasket will be good for 82mm.
Old Jun 3, 2008 | 04:16 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: 82mm itr build (all-mtr-teg)
I consistently see awesome numbers from both ImportBuilders pistons and Endyn.
OEM HG will work.
Old Jun 3, 2008 | 04:28 PM
powerfulperformance's Avatar
Default Re: 82mm itr build (2LEM1)
If you want factory type pistons you can get the Pr3 from Rs Machines. This will give u around 11.5 or so....
Modified by powerfulperformance at 6:33 PM 6/13/2008
Old Jun 3, 2008 | 05:14 PM
Default Re: 82mm itr build (powerfulperformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerfulperformance &raquo;</TD></TR><TR><TD CLASS="quote">If you want factory you can get the Pr3 from Rs Machines.</TD></TR></TABLE>
So is RS Machines getting OEM pistons for hella cheap, reboxing and selling them?
Old Jun 3, 2008 | 08:33 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">
So is RS Machines getting OEM pistons for hella cheap, reboxing and selling them?</TD></TR></TABLE>
they have their own made.
Old Jun 3, 2008 | 08:50 PM
Default Re: 82mm itr build (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">
they have their own made.</TD></TR></TABLE>
Yeah I know that,
Wat?
Old Jun 4, 2008 | 05:43 AM
projectcivicjp's Avatar
PR3 pistons are a stock cast from honda. RS Machine makes the same spec piston at a better quality with the heat resistant coating on the skirt. hope that helps. I have the PR3's from RS by the way and you will like em. the PR3 dome height on an itr rod is 6.01 or something like that and the P30 is 6.93. It was a little more than I wanted. if you do Enjoy
Old Jun 8, 2008 | 08:41 PM
Default Re: 82mm itr build (projectcivicjp)
I meant factory type pistons to be more clear. Honda doesn't make 82mm, so that why I recommend Rs 82mm pr3 pistons.
Whats your point? If you already know that, why are u asking such a dumb question?
Old Jun 8, 2008 | 09:06 PM
Whats your point? If you already know that, why are u asking such a dumb question? </TD></TR></TABLE>
I asked such a dumb question because
That sounds alot like you're saying RS is selling OEM Honda pistons, and while I know they are not OEM Honda pistons, others who are uninformed may have read your post and believe that RS Machine pistons are OEM. Eventhough they are good quality pistons and I'm running them in 2 of my own builds, I just wanted to clear that up and make sure others weren't getting the wrong idea.
Old Jun 8, 2008 | 09:28 PM
ekBlackHatch's Avatar
&lt;----- also 82mm RS pr3 pistons in itr block but with a ls crank and rod combo will put me at 11:3:1 cr with 1.880cc I cant wait to assemble just waiting for my damn cams to come
Old Jun 9, 2008 | 06:03 AM
Default Re: (ekBlackHatch)
It's gonna be a nice build
Old Jun 9, 2008 | 06:36 PM
Default Re: (all-mtr-teg)
ty i hope so. Hope i hit the over rated 200whp but i dont think i will with only a apexi neo stupid obd2 cars and emissions
Old Jun 9, 2008 | 07:13 PM
which cams are you using?
Old Jun 10, 2008 | 03:53 PM
s2s2 rocket recomended them seeings im only tunning with a adjuster I think ill end up switching to ectune or crome pro after break in and emissions though
Old Jun 10, 2008 | 03:54 PM
"tunning" lol woops
Old Jun 10, 2008 | 09:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekBlackHatch &raquo;</TD></TR><TR><TD CLASS="quote">s2s2 rocket recomended them seeings im only tunning with a adjuster I think ill end up switching to ectune or crome pro after break in and emissions though</TD></TR></TABLE>
What's an adjuster? Like an APEXi AFC NEO?
Old Jun 11, 2008 | 05:44 PM
ya a apexi neo
Old Jun 16, 2008 | 09:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c5stunna &raquo;</TD></TR><TR><TD CLASS="quote">im building a 82mm itr motor
thankss</TD></TR></TABLE>
So any updates? Did you decided on pistons yet?
Old Jun 17, 2008 | 08:18 PM
x2
boostedb20z
Oct 21, 2007 04:57 PM
PhatBoy5015
Aug 7, 2006 08:52 AM
str8sleepr
56
Apr 10, 2006 11:22 AM
93dx--hatch
Jul 2, 2005 05:51 PM
rusted_eyes
17
Jul 13, 2004 05:28 PM
