not good gas mileage. maybe its because of a code im throwing or chipped ecu? fix it please
Old Jun 3, 2008 | 12:37 PM
dontlooknow's Avatar
Default not good gas mileage. maybe its because of a code im throwing or chipped ecu? fix it please
my ls crx doesnt get that good of mileage, maybe low 20s highway. i hate it. its got a chip supposedly but i cant find it. it says j-k tunig on the ecu cover. i took some pictures that i'll load up soon.
its gota code 43 which is fuel supply system. i see lots of people with this and now it could beanything? i'm hoping its the oxygen sensor because that would make sense.
if my ecu is indeed chipped is it easy to just take it out? i'd like to run regular fuel again instead of premium
here are the pictures of the ecu. i see no aftermarket chip.
Modified by dontlooknow at 3:06 PM 6/3/2008
Old Jun 5, 2008 | 12:00 PM
traxxasx's Avatar
No chip.
o2 throw there own code.
Thins i would check.
timing
ignition timing
and all fuel related things.
Old Jun 5, 2008 | 01:03 PM
Janos Lin's Avatar
Default Re: (traxxasx)
It is indeed chipped. See where it says SST. That's the chip theyre referring to.
Best thing u can do about your chip that is to get it reflashed with a known stock LS basemap and go from there. The ECU will not work if it is absent.
Try replacing your o2 sensor first and see if that fixes it.
Janos
Old Jun 16, 2008 | 01:04 PM
Default Re: (Janos Lin)
could i also just swap for a stock pr4?
Old Jun 16, 2008 | 03:07 PM
traxxasx's Avatar
Default Re: (dontlooknow)
Yes u can.
singleslammer
Jul 14, 2008 09:43 AM
ShortyzKustomz
Dec 10, 2007 06:02 PM
d1nki
Nov 7, 2007 08:47 PM
95CivicGSR707
Apr 15, 2007 09:39 PM
Leviata-N
Oct 8, 2004 07:01 AM
