wideband wiring
i want to know how i would wire my wideband sensor into the engine harness so i can read the afr on my ecu for datalogging. does anyone know how to do this? can it be done? If i have this i can pull the basemap i am running off my ecu right?
it would help to know what wideband and tuning program you have.....
typically the widebands will have 0-1volt and 0-5volt inputs. The 5volt wire goes to the primary o2 sensor if using crome. (you must scale the wideband to read 0-3.8 volts). If you are using a program which can utilize the 5volts, wire it to ELD, EGR...etc.
Do you have a PLX SM-AFR module or just the wide band LSU4.2 Bosch O2 sensor itself?
If you have a complete PLX system there are manuals on there website.
Check them out.
http://www.plxdevices.com/M-Se...n.htm
If you do not have a wide band controller or module to run your LSU4.2 WB O2 it's not worth the hassle of hardwiring the WB O2 into a narrow band driven EMS.
Check them out.
seanyreeves
Engine Management and Tuning
Oct 12, 2011 10:15 PM
1992cxcivicEG
Dec 18, 2009 07:42 AM
