Do I need to retune my chipped P28 if I add a Catylitic convertor to my straight pipe?
Old Jun 3, 2008 | 09:39 AM
Budget Racer's Avatar
Default Do I need to retune my chipped P28 if I add a Catylitic convertor to my straight pipe?
The Question is above. Answers appreciated.
My setup:
D16y8 JRSC 6 P.S.I.
P28 chipped ECU with crome (No FMU)
RC 440 Injectors.
Short Ram intake
DC Header
2 1/4" Straight pipe exhaust
5 Zigen Fireball Muffler
Thanx!!!!!
Old Jun 3, 2008 | 11:27 AM
dpetro1's Avatar
Default Re: Do I need to retune my chipped P28 if I add a Catylitic convertor to my straight pipe? (Budget R
yes, any changes to the way the motor breathes will effect a/f ratio and turbo spool. especially a cat
Old Jun 3, 2008 | 11:32 AM
Snafubmx234's Avatar
I would throw a wideband on it and make sure everything is okay. It shouldn't change things that much, but better safe than sorry.
Old Jun 3, 2008 | 12:53 PM
Thanks for replies
By the way I want to use a High Flow cat and mainly just want it to quiet things down.
Modified by Budget Racer at 1:59 PM 6/3/2008
Old Jun 4, 2008 | 07:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">yes, any changes to the way the motor breathes will effect a/f ratio and turbo spool. especially a cat</TD></TR></TABLE>
Just wanted to note that I have a super charger, and not a turbo.
Does anyone know if a highflow cat would effect airflow much as far as tuning goes, and if so what cat would be the least restrictive? I only want to put the cat on to quiet my ride down. I thought of using an extra resonator, but they are fat and I'm not sure if I will have clearence issues, or if they will quiet things down as much as a cat would.
Knowledge masters please advise!!
&lt;breath, breath, breath&gt;
Old Jun 4, 2008 | 08:14 AM
TheShodan's Avatar
Moderator
A Carsound cat works very well, and considering you're only 6 psi, shouldn't effect it that much.
Also, you may consider simply adding a resonator. That would be even less restrictive than a high-flow Cat.
Old Jun 4, 2008 | 09:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">A Carsound cat works very well, and considering you're only 6 psi, shouldn't effect it that much.
Also, you may consider simply adding a resonator. That would be even less restrictive than a high-flow Cat. </TD></TR></TABLE>
Thanks for the suggestion. I'll look into that.
If I can fit a resonator then I might go that route.
Cheers!!
Old Jun 4, 2008 | 09:53 AM
[damn last comment posted twice. Doh edit edit edit
Old Jun 4, 2008 | 10:16 AM
HiProfile's Avatar
If you dont have emissions to deal with, you may want to even put two resonators on it. My last 3" exhaust I made was catless with 2 cheap summit resonators. It sounded very nice, although it was helped by the turbo as well.
As mentioned, it will change AFR's, but by how much I can't say. Speed-density (MAP sensor) ems's will not alter the open-loop/WOT fuel maps, and virtually any changed part will result in AFR differences.
Old Jun 4, 2008 | 01:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">If you dont have emissions to deal with, you may want to even put two resonators on it. My last 3" exhaust I made was catless with 2 cheap summit resonators. It sounded very nice, although it was helped by the turbo as well.
As mentioned, it will change AFR's, but by how much I can't say. Speed-density (MAP sensor) ems's will not alter the open-loop/WOT fuel maps, and virtually any changed part will result in AFR differences.</TD></TR></TABLE>
Yeah I've played with the idea of getting another resonator, but I don't think there is room for a big one. I don't think a small one would make much difference, but maybe. It's definately cheaper though. I'll just try it and let you guys know what happens.
Peace out 4 now!!
ihasacrayon93
May 24, 2009 10:16 AM
usdmEHboy
Jan 9, 2007 08:30 PM
BlueShadow
Dec 30, 2004 01:54 PM
danny98r
Jul 15, 2004 06:02 PM
