92 GS-R help! Engine harness questions.
I have a 92 Acura Integra GS-R
But I don't have the orignal B17A1 engine harness nor do I have the orignal engine.
What I did was swapped in a newer LS engine with the LS engine harness from another DA. Also the engine is a b18b1 from a 94 and the harness is from a 92 OBD1 DA engine harness
Just to get me going for now.
The problems that I'm encountering are that on the driver side, there is a total of 3 plugs on engine harness, but the chassis harness only has 1 that I can plug one into and the other is the injector clip and there is one just hanging by itself and it's a 6 pin plug, and that is on the engine harness side.
Also on the passenger side, there is only 2 plugs and the one that is left hanging is an 8 pin plug which is on the chassis side and not the engine harness side.
I tried starting the engine, but there isn't any spark. I have fuel but no spark.
Any input will be considered. Thank you for your time.
i no on mine (have original gsr wires) one is capd off one fits in the only one onthat side and for the other little plug i just ran to the pass side only one place 4 it togo on that side. as for other plugs danglin i have 3 it dosent seem to matter not 100% tho.
note i have b18b1 swap in mine
dingusjt
Aug 17, 2003 01:53 PM
