Steel Braided Fuel Lines- feed and return
yes, i have already done a search and i have a few more questions. I plan on running earl's -8AN steel braided line for my feed line and earl's -6AN steel braided line for my return line. My question is, how much should i order of each? I read that dustin ordered 25ft of -6an but i didnt know if he did both return and feed with this. Also, what earl's fitting part #'s do i order to install the lines to my fuel tank?
https://honda-tech.com/zerothread?id=142443&page=1
The fittings are dustin's 2nd pic on that link. Also, do you guys think i should get the aeromotive fuel filter? Thanks guys
that looks dank!!! bet thats like 300 dollars right there. anyway what the hell is the other line comming off the fuel rail the return my stock one dont have that.
the feed lines is about 2- 3 feet longer than the return lines...
so now we have..x + (x+3) = 25 heheheeh
x= 11 ft, feed ~ 14 ft, return ~ 11ft, just an approximate..this is assuming you;re running it the same way stock lines were ran..thru the bottom of the driver side and accross the firewall on the engine bay to the fuel filter...(if you still using the same spot of the stock fuel filter..)
I am tired....
I am tired....
I am tired....
I am tired....
thanx
I am tired....
is this for the turbo or filter? anyone know the sizes for the oil lines by earl's?
thanx
I am tired....
thanx
Hi, i was also wondering about this. can anyone give me a parts list for both the return and feed lines? thanx.
and you will find links there to dustin's fuel setup and also 93LCivic's...both have parts lists.
so can someone give me a definite answer of how much -8an feed and -6an return lines ill need for my fuel set up?
hey guys,
if you guys are planning on running fuel lines, i suggest that you guys use the teflon lined braided hoses instead of the rubber hoses.
the fuel vapors leak out of the rubber hoses, especially with cars that run FI fuel pressures...
just a tip..
just a tip..
hey guys,
just a tip..
just a tip..
21 1/2 feet ................I just did mine this past wekend and I used two (2) 51" hard lines for under the car and ended up using 13' of SS line to connect them to the tank and to the filter and FPR.
51" x 2 = 102" of hard line
102" / 12 = 8.5 feet of hard line + 13 feet of SS line = 21 1/2 feet total.
I will send you pics if you want. I am assuming you have an Integra?
[Modified by Farnsrocket, 4:18 PM 7/17/2002]
I will send you pics if you want. I am assuming you have an Integra?[Modified by Farnsrocket, 4:18 PM 7/17/2002]
send me some pics if you can, i would appreciate that. how do you like the hard lines? im running a h23a. my email is jdmh23a@aol.com, thanks. so whats the big diff about speed-flex, perform-o flex and the auto-flex hoses by earl's? from what i understood, perform-o flex would be adequate enough?
[Modified by GudeH23a, 9:39 PM 7/17/2002]
approx how much does it cost to do the fuel lines in ss or ss/hardline combo?
-erik
-erik
If you want to save some money, then go with the hard lines.
exactly how GOOD are the hard lines? i have the money for the earl's ss but its always good to save money though. i imagine you run them the same way you run the ss lines, but what about bending them and what not? are the hard lines the type of material that can bend quite easily? also, what fittings do you use on these? what is the longevity of these lines compared to the ss ones? im still new to the whole fuel line and fitting ordeal... give me a few days and ill have all my part #'s posted up hoping you guys can go over it with a fine tooth comb and make sure i have everything right. i REALLY appreciate all the help you guys have provided.
ok now i know how to run the hard lines thanks to Farnsrocket, whos set up may i add looks very impressive! i think im going to run hard lines under my car...
[Modified by GudeH23a, 10:11 PM 7/17/2002]
I am sure the hard lines are more durable than the SS lines. I bent them slightly with my knee, just so they would follow the brake lines that go to the tank. In the beginning, I bought a pipe bender and bought 60" hard lines and ended up having to bend them way too much to reach up to the tank, so I just took them back and exchanged them for 51" hard lines...........they fit flush with the stock hard lines to the points where they startt o bend up to the engine up front and up to the tank in the back.
one of these:
ask dustin.
12mm x 1.25 -6an 90 degree hose end, part # 849091 $28
(connects directly to top of stock fuel pump bracket)
-6 90degree bulkhead adapter, part # 983306 $9
(Drilled out stock return thing on fuel pump bracket, and used this)
boot machine 5000
Mar 26, 2003 04:07 AM
