Quick GE LS/VTEC question - oil lines & fittings
Old Jun 2, 2008 | 06:16 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Quick GE LS/VTEC question - oil lines & fittings
I currently have a turbo ITR motor (with a cracked sleeve ), that's running a Stealthmode firewall tee kit off of the oil pressure sender fitting, and is tee'd off with the electrical oil pressure gauge and -3 AN oil feed line.
I'm switching to a LS/VTEC, so naturally I'm going to pick up the GE kit. My question is - obviously I'm going to run the -6 AN line to the head, like so:
But what about that other small fitting on the other side of the sandwich plate? Is that supplied by GE? Is it a -3 AN fitting, or 1/8 NPT?
I'd like to run both feed lines for the turbo and head off of the sandwich plate, and then run the oil pressure gauge directly off the block (or extend it out to the firewall for safety).
Thoughts?
Old Jun 2, 2008 | 06:28 PM
OMG B16's Avatar
Default Re: Quick GE LS/VTEC question - oil lines & fittings (boostincoupe)
The other side of the oil plate is a 1/8 NPT thread. You put whatever fitting you want in it. I run both feeds off the ge adaptor, but im having oiling problems, im going to put my turbo feed from the stock oil pressure sending unit, and run my firewall sensor kit off the ge adaptor.
Old Jun 2, 2008 | 06:37 PM
Stealthmode Performance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">
I'm switching to a LS/VTEC, so naturally I'm going to pick up the GE kit. </TD></TR></TABLE>
Or you could pick up another brass tee and the -6 line and you're done.
Old Jun 2, 2008 | 07:03 PM
paulzy's Avatar
Default Re: Quick GE LS/VTEC question - oil lines & fittings (Stealthmode Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealthmode Performance &raquo;</TD></TR><TR><TD CLASS="quote">
Or you could pick up another brass tee and the -6 line and you're done. </TD></TR></TABLE>
^^^ the cheapest and most logical choice right here bro
Old Jun 3, 2008 | 05:09 AM
Steve, isn't that going to be too many tee's coming off of the oil pressure sender?
Any pics of this setup? Any oiling issues for the head or turbo at all?
I feel like my oil pressure gauge throws a wrench in the cleanliness of routing the oil line setup.
Old Jun 3, 2008 | 07:41 AM
Snafubmx234's Avatar
If you're worried about a tee off the oil pressure sensor just run another tee at the firewall kit.
Okay, now back to work
Old Jun 3, 2008 | 10:41 AM
Default Re: Quick GE LS/VTEC question - oil lines & fittings (Snafubmx234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snafubmx234 &raquo;</TD></TR><TR><TD CLASS="quote">If you're worried about a tee off the oil pressure sensor just run another tee at the firewall kit.
Okay, now back to work </TD></TR></TABLE>
That's already how I have it routed!
Old Jun 3, 2008 | 12:46 PM
Golden Eagle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">I currently have a turbo ITR motor (with a cracked sleeve ), that's running a Stealthmode firewall tee kit off of the oil pressure sender fitting, and is tee'd off with the electrical oil pressure gauge and -3 AN oil feed line.
Thoughts? </TD></TR></TABLE> that is a 3an fitting in the pic and we have them in stock and you will have no problem feeding your vtec and turbo off the sandwich plate we do it all the time with no problems
Old Jun 3, 2008 | 01:12 PM
Default Re: Quick GE LS/VTEC question - oil lines & fittings (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote"> that is a 3an fitting in the pic and we have them in stock and you will have no problem feeding your vtec and turbo off the sandwich plate we do it all the time with no problems </TD></TR></TABLE>
Do they come with the GE LS/VTEC kits? If not, what's the part number and price for that individual fitting?
Old Jun 3, 2008 | 01:21 PM
You only have one T on the block, the block fitting. Run another T off the T on the firewall kit and you'll have enough ports to do what you're trying to do. As far as oiling issues, you only have one oil pump, so no matter where you pull it from, or how many ports you have, it ends up being the same in the end.
Old Jun 3, 2008 | 01:52 PM
Do they come with the GE LS/VTEC kits? If not, what's the part number and price for that individual fitting? </TD></TR></TABLE> they don't come with the kit part number is gan3-18npt and the sell for $3.70
Modified by Golden Eagle at 11:47 AM 6/5/2008
Old Jun 3, 2008 | 03:13 PM
CerealKiller's Avatar
I use the GE kit, no problems ( approx. 2 years). I used to do the T fitting, to many leaks. just my 0.02
Old Jun 3, 2008 | 04:32 PM
Default Re: Quick GE LS/VTEC question - oil lines & fittings (CerealKiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CerealKiller &raquo;</TD></TR><TR><TD CLASS="quote">I use the GE kit, no problems ( approx. 2 years). I used to do the T fitting, to many leaks. just my 0.02</TD></TR></TABLE>
Sounds good. The only reason I created this thread is that I have three things that need oil:
- Turbo
- Head
- Oil pressure gauge
If it were just two items, it'd be easy to just run the GE kit or leave my current setup as is (Stealthmode fitting off the block, and oil pressure gauge T'd off on the firewall).
Old Jun 3, 2008 | 09:05 PM
AK94GSR's Avatar
i also run the GE kit with a turbo feed line off the other port of the sandwich plate
i put a tee in the stock oil pressure hole so i could install a sender unit for the oil pressure gauge. no leaks and no problems
Old Jun 4, 2008 | 08:18 PM
James Brown, is dead.
Modified by Stealthmode Performance at 12:28 PM 6/5/2008
Old Jun 5, 2008 | 08:31 AM
Default Re: Quick GE LS/VTEC question - oil lines & fittings (AK94GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK94GSR &raquo;</TD></TR><TR><TD CLASS="quote">i also run the GE kit with a turbo feed line off the other port of the sandwich plate
i put a tee in the stock oil pressure hole so i could install a sender unit for the oil pressure gauge. no leaks and no problems</TD></TR></TABLE> that's what i would do
Modified by Golden Eagle at 11:51 AM 6/5/2008
Old Jun 5, 2008 | 09:55 AM
Me Too.
Modified by Stealthmode Performance at 12:29 PM 6/5/2008
Old Jun 5, 2008 | 09:59 AM
HMTforlife's Avatar
I've been using stealthmode's block fitting for over 3 years, doesn't leak a drop and it works perfectly.
Old Jun 5, 2008 | 10:00 AM
its not sa sales pitch your the one with the sales pitch i have seen many t fittings brake if you have luck with them cool but t fittings braking and leaking is the reason we made a kit in the first place and if our sandwich plate is installed right there is no way its going to leak. i never said your kit leaked i never seen your kit i said taping the back of the block and using a t fitting is not the right way to di it because there prone to leaks
Old Jun 5, 2008 | 10:03 AM
HMTforlife's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">its not sa sales pitch your the one with the sales pitch i have seen many t fittings brake if you have luck with them cool but t fittings braking and leaking is the reason we made a kit in the first place and if our sandwich plate is installed right there is no way its going to leak.</TD></TR></TABLE>
What tee fittings are these? Cheap ones from someone's local hardware store?
Stealthmode's fittings don't break or leak either, stop generalizing the fact that you saw some cheap fitting break means that all types will.
Old Jun 5, 2008 | 10:05 AM
Hey, I can see a market for the oil sandwich. Installed correctly, I'm sure it's a great product.
Old Jun 5, 2008 | 10:20 AM
Under_Pressure's Avatar
There is not a "better" way to get oil. I use the T off system because it works great. Giving I dont use brass fittings u find at home depo. Either way both would work but ill go with the T unit. I dont want to have two plates in between my oil filter "oil cooler & GE block"....
Old Jun 5, 2008 | 10:21 AM
8herout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">its not sa sales pitch your the one with the sales pitch i have seen many t fittings brake if you have luck with them cool but t fittings braking and leaking is the reason we made a kit in the first place and if our sandwich plate is installed right there is no way its going to leak. i never said your kit leaked i never seen your kit i said taping the back of the block and using a t fitting is not the right way to di it because there prone to leaks </TD></TR></TABLE>
Mine leaked like crazy. It doesn't take a genius to install them does it?
Old Jun 5, 2008 | 10:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealthmode Performance &raquo;</TD></TR><TR><TD CLASS="quote"> Hey, I can see a market for the oil sandwich. Installed correctly, I'm sure it's a great product. The problem I have is when people are told that that's the only correct way to get oil to the turbo. It's simply not true, and history says I'm right. </TD></TR></TABLE> cool you have a way that works for you. i was less talking about your kit and more talking about the cheep t fitting a lot of guys use and tap in the there blocks that are known for leaks and braking. nothing agents your kit sorry if it came off that way
Modified by Golden Eagle at 11:30 AM 6/5/2008
Old Jun 5, 2008 | 10:25 AM
HMTforlife's Avatar
How old is this kid working for GE, 13?
