ECU Code 8? Question - Top Dead Centre Sensor. TDC
You'll need to replace the distributor assembly. The sensor is not sold separately.
It's much easier to swap out the entire distributor rather than cutting and soldering in another used sensor and then trying to adjust the air gap perfectly. I've done it before and it has worked just fine, but it's not something i would recommend.
Thanks, i just found this site actually, really cheap distributors.
http://www.hondadistributors.net/
I think this will be the cheapest route.
$C-BRAM$
Feb 12, 2010 09:34 AM
quik89
Nov 30, 2003 06:43 PM
