99 Hatch W/ LS Swap. A/C Question HELP!!!!!!!
I recently Swapped my D16y7 for an LS everyting on my car is OBD2 Except i have my jumper harness to OBD1 for my chipped ECU. Now my situation is I dont have my A/C hooked up. I read somewhere that in order to use my stock A/C lines I would have to get a Del Sol bracket, therefore I would be able to use my stock compressor aswell. My friend has a Intregra (LS) compressor, but I dont think I would be able to use that one w/ my stock a/c lines. I really dont know the best way to hook up a/c, I'd like to keep my stock lines. Or spend as little money as possible. Let me know what you all think I cant take driving in traffic w/ no a/c its killing me.
Modified by Manny1987 at 6:09 PM 6/2/2008
i have the exact same setup as you, you would have to use everything off your original a/c setup and use either a del sol bracket or a crv. And to mention the a/c belt also. Pretty much it's a really easy setup if you know what your doing. Then after you just take it to a shop and get it charge.
Im going today to get the CRV bracket and belt, Could I use the CRV compressor to or would I have to stay with my stock one? I just want to double check cuz I dont know whether to get the compressor while im out getting the bracket I know I have to get the belt for what ever bracket I go with tho.
SleeperEG-B
Jun 19, 2003 07:52 AM
ghettochild
Nov 27, 2002 11:46 AM
