Code 16 help need
Old Jun 2, 2008 | 03:15 PM
red91hatch's Avatar
Default Code 16 help needed
My 91 civic (DPI) is throwing a code 16. It is fine in city driving. The car runs in low rpm but when in higher rpm it will stutter and start to cut out. I started by ohming out the injectors and got 1.3 on the secondary and 6.2 on the primary witch should be within specification. Also with the car running I have 1.2v going to the secondary injector. Next I unplugged the secondary injector and drove the car. There was no change in performance with the secondary injector unplugged. With that being said can the secondary injector be bad and still ohm out ok? If so how can I test to confirm that it is bad? Can a fuel delivery issue threw an injector code? Thanks for your time.e
Modified by red91hatch at 4:44 PM 6/2/2008
Old Jun 6, 2008 | 06:23 AM
Mr. Em1's Avatar
Default Re: Code 16 help needed (red91hatch)
bump cause im havin the same problem with mine
lsvSwagg
Jan 29, 2013 07:46 AM
conantech
11
Mar 11, 2011 08:20 AM
93cavRS
11
Oct 11, 2006 01:25 PM
slywfbpsi
Jun 9, 2003 11:07 AM
