need help: problems starting
Old Jun 2, 2008 | 11:18 AM
jameslewis178's Avatar
Default need help: problems starting
sometimes it kicks over and sometimes it wont. the starter has been changed and that wasnt the problem and i have checked all the wires. is there a relay or something i need to check?
Old Jun 2, 2008 | 11:27 AM
Jimmy's Avatar
Global Moderator
When this happens do you hear the fuel pump prime?
If you don't hear the fuel pump i'd be willing to bet it's the PGM-fi main relay.. located next to your hood release cable.. it's a grey box.. with brown on it and a connector.. with a 10mm holding it in..
Try tapping it untill you hear the fuel pump come on.. for a permanent fix remove the relay.. remove the relay cover and soldier the dry joint and reinstall.. problem fixed.
**edit**
that is if this is for a 92-95.
Old Jun 2, 2008 | 01:20 PM
Former User's Avatar
Default Re: need help: problems starting (jameslewis178)
Check the starter switches on the clutch pedal or AT shifter. Also test the starter cut relay (MT), if relevant.
Old Jun 3, 2008 | 06:40 PM
thanks ill try them both tomorrow
Old Jun 8, 2008 | 03:35 PM
delsol210's Avatar
Hi just had my gsr bottom end built for turbo now the car won't start, if it does start it funs for 20 seconds and dies any any gas given to it it kills it right away. any1 have this problem got a basemap from xenocron can't get it to run and idle
thanks
Old Jun 9, 2008 | 09:46 AM
Default Re: need help: problems starting (delsol210)
Check all your grounds
Old Jun 9, 2008 | 09:56 AM
team_exceed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol210 &raquo;</TD></TR><TR><TD CLASS="quote">Hi just had my gsr bottom end built for turbo now the car won't start, if it does start it funs for 20 seconds and dies any any gas given to it it kills it right away. any1 have this problem got a basemap from xenocron can't get it to run and idle
thanks </TD></TR></TABLE>
hi, this is called thread jacking... start your own thread!
to the op, do exactly as jimmy said. my buddies 92 hatch was this way, thats exactly what we did, and now it works every time!
Scarykiiid
Apr 9, 2011 06:08 PM
93siturbo
May 7, 2009 07:31 AM
White98LS
Jul 14, 2007 07:46 AM
IIDIEIV619
18
Oct 11, 2006 11:54 AM
hookedonvtec
May 27, 2004 08:17 PM
