90-93 Integra Half-Sized Radiator?
Alright here is the deal the 90-93 integras have a full size radiator one side for the engine the other for the A/C. Since I got the AC removed and my radiator recently cracked. So what application do I go for to replace it with a half size?
i would just get one from autozone or your local parts store for a civic or del sol. Should be under $100 w/ warranty. If you are worried about cooling issues make sure its the 2 row one. Also a push/pull fan setup would be optimal. I have no cooling issues with this method.
Um no, the 90-93 has a full sized radiator in front for the motor and behind it is the full sized condenser for the AC. If you get a half sized radiator it is not going to keep your motor as cool as it should
Never heard bad things about those company. You will be paying more but I believe they're full aluminum. They have both half and full size, just order for the application. With the half rad, no matter which brand, you will most likely have to fab brackets.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxstylin »</TD></TR><TR><TD CLASS="quote">Um no, the 90-93 has a full sized radiator in front for the motor and behind it is the full sized condenser for the AC. If you get a half sized radiator it is not going to keep your motor as cool as it should</TD></TR></TABLE>
i'm not going to be ignorant but i've proved your last statement wrong and along with a few *understatement* integra members. If i'm cruising around i usually dont even have to turn my fans on and it stays below the middle in temp.
Modified by LoseRPunKx182 at 8:45 PM 6/2/2008
thx alot. I picked up a full sized mishimoto radiator full sized for 220 from a local dealer.
ill post updates on it and pics later.
