what will happen if i manually engadge vtec soenoid on f22b1
Old Jun 2, 2008 | 09:52 AM
hitchris22's Avatar
Default what will happen if i manually engadge vtec soenoid on f22b1
i just found out since i had this car that the vtec was not hooked up and cannot find the wire to plug in to the solenoind
Old Jun 2, 2008 | 10:14 AM
GhostAccord's Avatar
Default Re: what will happen if i manually engadge vtec soenoid on f22b1 (hitchris22)
That all depends on when you open it. It could cause your car to run poorly if not opened at the proper time. It won't blow up if that's what your worried about. It's just that your fuel and ignition maps/ ECU fuel delivery information will not match the VTEC. Therefore you could run into a lean fuel condition or possibly stalling???? I've never tried running VTEC without a VTEC ECU. That is basically what you would be doing buy switching it manually.
What model Accord is this? Do you have a CEL light on, if not then I would assume that your car is not running a VTEC ECU. A VTEC ECU will through a Diagnostic Trouble Code if the VTEC isn't operating.
Old Jun 3, 2008 | 08:41 AM
hitchris22's Avatar
its a94 accord, and i bought at a auction and i think that it was a lx and and had the ex engine put in it, and no the engine light doesnt come on
Old Jun 3, 2008 | 08:46 AM
hitchris22's Avatar
so if i engadge the solenoind for a second to see what happens it probally with run rich and then go back to normal ops
GlennKDM
Oct 9, 2017 11:55 PM
tinasteele
Mar 28, 2012 03:46 AM
Bacondoggy
Oct 8, 2009 04:14 PM
moosepoop21
Aug 29, 2006 05:39 AM
digitalhav0c
Apr 9, 2002 11:05 AM
