Vibration when braking at high speeds
Old Jul 16, 2002 | 12:13 PM
ExAcc's Avatar
Default Vibration when braking at high speeds
Why is it that I get loud vibrations when I brake while going 60 MPH plus, but not when below 40 MPH. Could I have warped discs?
Old Jul 16, 2002 | 12:17 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Vibration when braking at high speeds (ExAcc)
Indeed, get those rotors checked out.
Old Jul 16, 2002 | 12:29 PM
chotchkie's Avatar
also if your hitting the brakes hard the rotors are probably getting too hot and expanding, which would multiply the feeling of warped rotor
Old Jul 16, 2002 | 09:19 PM
TypeSH's Avatar
Default Re: Vibration when braking at high speeds (chotchkie)
try checking your lug nuts. Retorque them to 80ft-lbs.
Old Jul 16, 2002 | 09:22 PM
Accord94DX's Avatar
Default Re: Vibration when braking at high speeds (TypeSH)
rotors...have fun.
Old Jul 17, 2002 | 04:06 AM
John's Avatar
New User
If you decide to replace your rotors, here's the step-by-step DIY guide: https://honda-tech.com/zerothread?id=223096
Old Jul 17, 2002 | 04:25 AM
Kazmans94cord's Avatar
Default Re: Vibration when braking at high speeds (DunReit)
speaking of changing rotors...tomm. i am goin to a junk yard...ill be lookin for new calipers...which ones should i get...i am doin the swap....should i go for the dual pistons or singles?
Old Jul 17, 2002 | 12:59 PM
Default Re: Vibration when braking at high speeds (kazmans94cord)
anyone?? pwease...
Old Jul 17, 2002 | 07:11 PM
go_noles28's Avatar
Does your car have ABS? if not I feel your pain. Its really bad when going 110 mph or so. Can anyone tell me if resurfacing will do any justice or do they have to be replaced?
Old Jul 17, 2002 | 07:13 PM
TypeSH's Avatar
Default Re: Vibration when braking at high speeds (go_noles28)
Did you check your lug nuts? I had the exact problem, turned out to be unevenly torqued lug nuts when 2-3 weren't torqued down as much as the others.
Old Jul 17, 2002 | 07:20 PM
Gennady's Avatar
New User
Mine are torqued to 80 all the time now, and I still have the problem. As far as I know, new front pads and rotors and a proper break-in is what is needed.
Old Jul 17, 2002 | 07:37 PM
go_noles28's Avatar
QUOTE]Did you check your lug nuts? I had the exact problem, turned out to be unevenly torqued lug nuts when 2-3 weren't torqued down as much as the others.[/QUOTE]Thats interesting I did not know that thanks for that tidbit.[
Old Jul 17, 2002 | 08:50 PM
does noone want to help shan today?? comon...oh well i think ill just go look for the V6 calipers...im thinkin the legends are overkill.
Old Jul 17, 2002 | 08:52 PM
Brandon's Avatar
Life is Suffering
Try the Legend.
Old Jul 17, 2002 | 08:53 PM
Default Re: Vibration when braking at high speeds (accordvtec)
dual pistons eh?
Old Jul 17, 2002 | 08:57 PM
Brandon's Avatar
Life is Suffering
dual pistons eh?
It's what I would do if I could.
Old Jul 17, 2002 | 09:08 PM
if you could..what do you mean? im just worried about the propotioning.
Old Jul 17, 2002 | 09:11 PM
Brandon's Avatar
Life is Suffering
Money.
Old Jul 18, 2002 | 03:54 AM
ahhhhh......
Old Jul 18, 2002 | 05:04 AM
Gennady's Avatar
New User
Go V6. Legend is overkill and unnecessary. Your not running Le Mans are you?
Old Jul 18, 2002 | 07:01 AM
Default Re: Vibration when braking at high speeds (Wont be beat)
hell yeah i am...i thought i told you?? well im leavin in about 2 secs after i type this...dude said $75 for both calipers....im guessin thats pretty good...i was thinkin between $60-80.
btw...its the V6 calipers.
[Modified by kazmans94cord, 10:01 AM 7/18/2002]
Old Jul 18, 2002 | 05:51 PM
Gennady's Avatar
New User
Um, no, thats not very good. I $45 each is more like it.
Old Jul 18, 2002 | 08:44 PM
when i said between $60-75 i meant for both...i got them for $80.44 with tax...not bad eh?
Old Jul 18, 2002 | 09:10 PM
Brandon's Avatar
Life is Suffering
. Can you get me some too?
Old Jul 18, 2002 | 09:11 PM
yeah sure...im pretty sure they have more there.
