FS / FT / WTB LIST: CIVIC HATCHBACK DEL SOL INTREGRA PARTS & MORE
<FONT SIZE="18"><FONT COLOR="darkblue">HONDA OEM S2K NETS</FONT></FONT>
<FONT COLOR="darkblue">DESCRIPTION:</FONT>
HONDA S2000 NETS
*DRIVER SIDE DOOR NET
*PASSENGER SIDE DOOR NET
*CENTER MAP NET
<FONT COLOR="darkblue">CONDITION:</FONT> NEW
<FONT COLOR="darkblue">PRICE:</FONT><FONT SIZE="18"><FONT COLOR="darkblue">$ obo</FONT></FONT>
<FONT COLOR="darkblue">PICTURES:</FONT>
_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/
<FONT SIZE="18"><FONT COLOR="darkblue">TOYOTA / LEXUS H4 HID SET UP COMPLETE</FONT></FONT>
Toyota denso hid setup perfect for brightening up you rides sight... comes wil all you see
*bulbs
*balast
*ignighters
*wire harness
*relays
*h4 -> d2s shrouds
<FONT COLOR="darkblue">CONDITION:</FONT> used
<FONT COLOR="darkblue">PRICE:</FONT><FONT SIZE="18"><FONT COLOR="darkblue">$350 obo</FONT></FONT>
<FONT SIZE="18"><FONT COLOR="darkblue"> DEL SOL MUGEN OR TYPE R POLY URETHANE LIPS </FONT></FONT>
fits all del sol oem bumpers with slight modification
<FONT COLOR="darkblue">CONDITION:</FONT>NEW
<FONT COLOR="darkblue">PRICE:</FONT><FONT SIZE="18"><FONT COLOR="darkblue">$70</FONT></FONT>
<FONT SIZE="18"><FONT COLOR="darkblue">GREDDY EVO 2 EXHAUST</FONT></FONT>
GREAT NON RICY TONE SMOOTH AND DEEP
MUST BE INSTALLED @ MUFFLER SHOP (WELDED ON) s/ (NOT BOLT ON)
CHECK THE RETAIL ON THESE!!!
FROOGLE GREDDY EVO 2
WANT TO HEAR THE SOUND... HERE ARE SOME VIDEO LINKS
<FONT COLOR="darkblue">CONDITION:</FONT>USED
<FONT COLOR="darkblue">PRICE:</FONT><FONT SIZE="18"><FONT COLOR="darkblue">$200 / TRADES</FONT></FONT>
<FONT SIZE="18"><FONT COLOR="darkblue">BLACK SKINNY FIVES</FONT></FONT>
<FONT COLOR="darkblue">DESCRIPTION:</FONT>used skinny fives in great condition sure they are painted black but they better than steelies... include center caps tires not included but i can get a set of brand new tiers for $200
<FONT COLOR="darkblue">CONDITION:</FONT> painted and used
<FONT COLOR="darkblue">PRICE:</FONT><FONT SIZE="18"><FONT COLOR="darkblue">$90 W/O tiers OR $290 with brand new tires</FONT></FONT>
<FONT SIZE="18"><FONT COLOR="darkblue">REPLICA MUGEN FRONT BUMPER</FONT></FONT>
EXACT REPLICA OF MUGEN BUMPER BUT WITH THE ADITIONAL AUX LIGHT HOLES...
<FONT COLOR="darkblue">CONDITION:</FONT> MINT
<FONT COLOR="darkblue">PRICE:</FONT><FONT SIZE="18"><FONT COLOR="darkblue">$250</FONT></FONT>
<FONT SIZE="18"><FONT COLOR="darkblue">STR COMPETITION FUEL RAIL</FONT></FONT>
<FONT COLOR="darkblue">DESCRIPTION:</FONT>The STR Power Fuel Rail is completely redesigned. Featuring a larger fuel supply, the STR Power Fuel Rail will provide your Fuel Injectors with more fuel to meet increased demand. Adding an STR Power Fuel Rail works great when used with a larger throttle body and fuel injectors. The STR High Flow Fuel Rail will bolt on in Place of your Factory Fuel Rail. The STR Fuel Rail is made from CNC Billet Aluminum and available anodized in Titanium, Bronze, Blue, Red, Silver. STR Fuel Rails are Designed to Handle up to 1000 Horsepower on Turbo Race Applications and install in 1 hour or less.
<FONT COLOR="darkblue">CONDITION:</FONT> USED
<FONT COLOR="darkblue">PRICE:</FONT><FONT SIZE="18"><FONT COLOR="darkblue">$80</FONT></FONT>
<FONT SIZE="18"><FONT COLOR="darkblue">Koss 6 Disc Cd Changer Ms565</FONT></FONT>
Technical Details
* Operating Voltage: 10-15V Current: 400mA
* Cartridge holds 6 Compact Discs
* Audio: 20Hz - 20kHz (+/- 1dB)
* Dynamic Range: 90dB Distortion: 0.1%
Product Details
* Product Dimensions: 7.3 x 11.2 x 2.9 inches ; 5 pounds
* Easy instalation
* ASIN: B000L6HDD0
* Includes mounting brackets
* Remote Control
<FONT COLOR="darkblue">PRICE:</FONT><FONT SIZE="18"><FONT COLOR="darkblue">$45</FONT></FONT>
<FONT SIZE="18"><FONT COLOR="darkblue">Clarion APA2160 2/1 Ch. Amp W/Bass Extender Control</FONT></FONT>
RMS Power Output: 80W x 2 @ 4 Ohms
Peak Power Output: 160W x 2 @ 4 Ohms
Birdged Output: 320W x 1 @ 4 Ohm
Frequency Response: 55Hz-550Hz
Bass Boost: 0~15dB @ 45Hz
Built-In Crossovers: HP LP
Ohm Load Stability: 2 Ohm
Low Level Input: Yes
Built in Cooling Fan: Not Specified
Bass Control ****: Yes
* Maximum Power Output 320W
* Continuous Average Power Output 160W (80W x 2 Into 4 Ohms 20Hz-20kHz @ 0.05% THD)
* Typical 2-Ohm Stereo 125W x 2 @ 0.2% THD
* Typical 2-Ohm Bridged Power 1kHz 250W x 1 @ 0.2% THD
* Bass Extender Control 0~15dB @ 45Hz
* Adjustable 55Hz-550Hz, 12dB/oct. High/Low-Pass Crossover
* Mixed- Mode Operation
* Built in Bridging capability
* MOS-FET Output Design
* Speaker Level Inputs
* Double-Sided FR4 PC Board
Utilized in the power supply circuitry, Gapped E core choke coils offer low impedance, making them resistant to harmful magnetic noise. This results in a more efficient amplifier and a low-noise power supply, which is important when achieving crystal clear sound. Variable High/Low-Pass Crossover Select amplifiers have built-in low-pass and high-pass filters allowing for adjustment in the APA2160: 55Hz to 550Hz range over all channels. This allows for easy configuration of more complicated sound systems that encompass multiple amplifiers and sub woofers. Clarion’s amplifiers offer increased conductivity and low signal loss. Gold has an extremely low electrical resistance and low contact resistance, which helps prevent voltage drops, noise, heating and other problems from occurring. APA Series amps feature a die-cast design that boasts countless heat sinks for highheat dissipation. This eliminates the need for an internal fan. Also preventing overheating is the amplifier’s circuit design that inhibits heat dispersal. This heat dispersal effect is maximized during consecutive drives for high power in minimal space.
<FONT COLOR="darkblue">CONDITION:</FONT> new
<FONT COLOR="darkblue">PRICE:</FONT><FONT SIZE="18"><FONT COLOR="darkblue">$180</FONT></FONT>
<FONT SIZE="18"><FONT COLOR="darkblue">CUSTOM DEL SOL TRUNK STEALTH BOX WITH JL AUDIO SUBS REMOVABLE FOR RACE/TRACK/STORAGE APPLICATION</FONT></FONT>
<FONT COLOR="darkblue">DESCRIPTION:</FONT>2 jl subs in a sexy box for the del sol trunk
<FONT COLOR="darkblue">CONDITION:</FONT>used
<FONT COLOR="darkblue">PRICE:</FONT><FONT SIZE="18"><FONT COLOR="darkblue">$275</FONT></FONT>
<FONT SIZE="18"><FONT COLOR="darkblue">6.5" INFINITY KAPPA 62.5 2 WAY SPEAKERS (SET OF 4) </FONT></FONT>
<FONT COLOR="darkblue">DESCRIPTION:</FONT>MPN 62.5i
Key Features
Car Speaker Type Coaxial
Elements 2-Way
Car Speaker Function Subwoofer • Tweeter
Size 6.50"
Nominal Power Handling 75 Watt RMS
Powered Non-Powered
Technical Features
Peak Power Handling 225 Watt
Frequency Response 45 Hz - 21 kHz
Sensitivity 90 dB
Impedance 4 ohm (Dual Coil)
Components
Tweeter Design Dome Size 1"
Top Mounting Depth 2.19 In.
Mounting Diameter / Length 5.00 In.
KAPPA62.5I
6-1/2" two-way loudspeaker with Plus One woven glass-fiber woofer cone and edge-driven MMD dome tweeter.
• Plus One woofer cones - This patent pending technology deliver a cone with more surface area than competing models of the same size. The result is increased bass output and higher efficiency.
• Edge-driven MMD dome tweeters - These are not commonly used W-domes, but fully edge driven domes like those found in fine home audio loudspeakers. This much larger voice coil increases power handling and provides better sonic integration with the mid-woofer.
• Unipivot - To ensure proper imaging the 62.5i utilizes a patented rotating tweeter (patent no. 6,002,780). So even if the speaker is mounted down low in the door, the soundstage can be brought up and optimized for the listener's location.
• Intermount III mounting system - Allows for installation of the 62.5i in all 6-1/2" hole size standards without the need to purchase additional adaptors or mounting kits.
• Woven glass fiber woofer cone material is extremely stiff, minimizing cone flex which yeilds very low distortion and improved clarity, an Infinity trademark.
• SLI high-output design. Conventional 4-ohm speakers do not leverage allof the power available from today's car audio amplifiers and high-powered head units. This topology extracts every last watt from the amplifier source, increasing overall system output and efficiency.
• Computer-optimized voice-matched outboard passive crossovers - Each Kappa multielement and component system features an outboard crossover that has been voice-matched using audiophile grade air core inductors and polypropylene capacitors. The result is flawless performance with incredible detail and accuracy.
• Adjustable tweeter level -Each Kappa multielement features a user adjustable tweeter level control. On the two-way models, simply rotate the tweeter to add or subtract 3dB output.
<FONT COLOR="darkblue">CONDITION:</FONT> mint
<FONT COLOR="darkblue">PRICE:</FONT><FONT SIZE="18"><FONT COLOR="darkblue">$150</FONT></FONT>
<FONT SIZE="18"><FONT COLOR="darkblue">[/color]</FONT>
[color=darkblue]CONDITION:</FONT> NEW
Modified by LsDecepticon at 7:39 PM 6/2/2008
HONDA S2000 NETS
*CENTER MAP NET
*bulbs
*balast
*ignighters
*wire harness
*relays
*h4 -> d2s shrouds
Technical Details
Product Details
* Easy instalation
* ASIN: B000L6HDD0
* Remote Control
Key Features
Elements 2-Way
Size 6.50"
Powered Non-Powered
Technical Features
Sensitivity 90 dB
Components
KAPPA62.5I
