Cast iron welding?
Old Jun 2, 2008 | 04:19 AM
TurboEK9Coupe's Avatar
Default Cast iron welding?
I tried searching but couldn't really find a good result. I want to weld a v-band flange adapter to my exhaust housing but I'm not sure of what rod to use? And would this be strong enough? Thanks
Old Jun 3, 2008 | 03:43 AM
jzz30's Avatar
they make a cast iron SMAW rod. you can just brake off the flux coating and use that. then maybe go over it with a nice high nickel content rod such as Monel rod if you want. just make sure you pre-heat and slow cooling rate by throwing it in a bucket of sand or wraping a towel over it.
Old Jun 3, 2008 | 09:58 AM
pythoner's Avatar
a tip for welding cast iron is to heat it up... like 400 or so
If you don't it will most likely crack and it won't weld well but tig it with the stick wire and you should be fine.
TIGboy
Welding / Fabrication
21
Dec 3, 2011 04:45 PM
all_motor_mike
Jan 26, 2008 02:08 PM
55superbeetle
Oct 2, 2007 10:14 PM
dfoxengr
40
Jun 27, 2007 07:36 AM
JDMCRX
Sep 6, 2006 03:43 PM
