HELP
Old Jun 2, 2008 | 03:20 AM
sleepa's Avatar
Default HELP
89 crx with minimi swap. alternator needs to be replace...ok how do i even start unbolting?? how many bolts and wat special tools are needed?
Old Jun 2, 2008 | 01:42 PM
stevew84's Avatar
Banned
Default Re: HELP (sleepa)
normally this is when people give u smart *** remarks.... but you just need to sockets, dont remember the size sorry but no special tools.
but its only two bolts you have to mess with.
1. the "Tension Bolt" that is on the top of the alternator, the bolt goes thru a groove that allows it to slide so when you unbolt this, you can rock the alternator back and forth.
2. the alternator "thru bolt" is on the bottom, about a 4 inch bolt with a nut on one that you have to remove, with a little bit of wiggling of the alternator this bolt will come out. during all of this, you can remove the belt after step 1.
to install reverse the order.
Old Jun 2, 2008 | 02:10 PM
hailchristian's Avatar
Default Re: HELP (stevew84)
Im pretty sure the tensioner bolt is a 12mm and the lower bolt is either a 14mm or 17mm
Old Jun 2, 2008 | 11:40 PM
sleepa's Avatar
thank you gentlemen for not ******* my post. i can finally get my car running before it gets jack
Old Jun 3, 2008 | 12:00 AM
draperj09's Avatar
Default Re: (sleepa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepa &raquo;</TD></TR><TR><TD CLASS="quote">thank you gentlemen for not ******* my post. i can finally get my car running before it gets jack</TD></TR></TABLE>
People wouldn't have to "dog" your post if you didn't have to put a useless title. Just try to be more specific that way people know what the thread will be about. Thanks.
Old Jun 3, 2008 | 04:31 AM
90teg91hatch's Avatar
Default Re: (draperj09)
No they will dog your thread b/c they will simply put " thats a stupid question, why dont you look at the car yourself" b/c a lot of people on here are decks about things
blaze_125
Sep 24, 2007 06:14 AM
kaoss_11
Jul 15, 2004 12:22 AM
RJL
Sep 20, 2001 07:10 PM
