PLEASE HELP! A/C Question!!!!!
Old Jun 2, 2008 | 01:12 AM
funkyfreshpnoy's Avatar
Default PLEASE HELP! A/C Question!!!!!
yOyOHT! so basically heres the scoop:
so basically im having a wiring/electrical problem w/ the a/c system. the entire system works and all the lines are okay because the whole system works one minute and then later on it doesn't work. its an on/off thing. i unplugged the diode and plugged it back in and the compressor/ everything worked fine. later on it stopped again after i turn off the car. but then it comes back on again afterwards.... im 99% sure its electrical. im assuming its the relays because its an on/off thing.... but not quite sure. btw the fans/compressor don't work as a result when i say "its not working" .
plz give me your .02 cents. thanks thanks!
Old Jun 7, 2008 | 10:59 PM
modafcker's Avatar
Default Re: PLEASE HELP! A/C Question!!!!! (funkyfreshpnoy)
Does your civic having the following similar problem?
The A/C works normally under cool weather.
The A/C works for 10-15 mins under hot weather, then it stops working; turn it off for awhile, then it will work again for 10-15mins.
Elemento
Honda CR-V & Element
Sep 5, 2017 11:50 PM
klep1708
Jul 22, 2013 04:31 PM
ssd
Aug 30, 2005 01:40 PM
diehlr
Jun 9, 2005 05:38 PM
Elisa
Nov 27, 2003 10:46 AM
