Trailing Arm e brake cable bracket removal?
Old Jun 2, 2008 | 12:57 AM
B204door's Avatar
Default Trailing Arm e brake cable bracket removal?
I searched everything and the only answer i found was to use a solder torch and make the hole bigger. i dont have a solder torch and nothing really that could make the hole bigger. i remember doing the other trailing arm and had trouble with it but i did get it but i cant remember how. im talking about when your removing the trailing arm i cant get that bracket on the ebrake to fit threw the hole so that the trailing arm will let loose. please gimi some help on how to get it off i gota get the car on the ground tomorow morning! thanks
Old Jun 2, 2008 | 05:05 AM
elmalouno's Avatar
Default Re: Trailing Arm e brake cable bracket removal? (B204door)
which direction are you trying to pull the bracket through? you definitely do NOT need to torch your chassis to remove the ebrake cables. I am just not sure where you are having trouble.
Old Jun 2, 2008 | 10:15 AM
B204door's Avatar
no im trying to take my trailing arm off the car. the eb rake cable goes through a hole in the trailing arm and theres a bracket that bolts onto the caliper im trying tho get that bracket to fit threw the hole in the trailing arm so i can pull it off. that bracket is supposed to come off but its not. i alredy too the C clip thats holding it down. its a DA btw if theyre any diferent from DC's
Old Jun 2, 2008 | 01:28 PM
elmalouno's Avatar
Default Re: (B204door)
remove the clevis pin from the caliper arm, the the C clip from in front of the bracket. once these are free the cable will pull through the bracket and you can remove it.
Old Jun 2, 2008 | 03:34 PM
B204door's Avatar
Default Re: (elmalouno)
dude its not coming off the cable. i feel like the cable is about to rip im pulling on it as hard as i can!
Old Jun 2, 2008 | 04:00 PM
elmalouno's Avatar
is it really rusty?
Old Jun 2, 2008 | 04:12 PM
B204door's Avatar
a little nothing to crazy. i dont even no where the bracket ends, it like goes into the rubber thats covering the e brake cable.
Old Jun 2, 2008 | 04:48 PM
B204door's Avatar
come on guys . how do u get the bracket off any methods? twisting hamering? i dont even no were the brcket starts and ends. well it starts were that c clip is but where does it end?
troppysteg
Suspension & Brakes
Feb 2, 2015 08:44 AM
JohnS_93
Dec 18, 2006 03:12 AM
eg6_rick
Jun 29, 2005 02:48 PM
hayabusa160
Jun 9, 2005 09:38 PM
