car dying
Old Jun 1, 2008 | 09:42 PM
Slo_Accord's Avatar
Default car dying
for some reason in the past month or so my car has died while im driving twice. i just had the 150k recall done back in december. i do however have a 1200 watt amp that has been in my car since september, i dont know if that matters or not. but if thats the case im sellin that bitch!(amp/sub) thanks
Old Jun 2, 2008 | 06:39 AM
nguyener's Avatar
Default Re: car dying (Slo_Accord)
year and model would be nice...
Old Jun 2, 2008 | 08:25 AM
dansaleen_04's Avatar
dude have u checked ur alt? i know i had the same problem awhile back and my alternator had its points fried because of the power consumption. so u might want to take a look at it at the auto part store.
Old Jun 3, 2008 | 08:40 PM
Slo_Accord's Avatar
its a 97 lx. and what do you mean fried points?
Old Jun 4, 2008 | 06:35 AM
HONCORD's Avatar
Default Re: (Slo_Accord)
Upgrade to a higher amp alternator. You trying pull more power out of your car than the alternator can produce. So I'm guessing its fried.
Old Jun 4, 2008 | 04:09 PM
Slo_Accord's Avatar
if i were to get a new one how much would it be and how long would it last with my current setup. i might just sell my setup and get a 200rms amp then, or would i still need a new alternator. would a capacitor be an option?
Old Jun 7, 2008 | 09:10 PM
Slo_Accord's Avatar
bump?
Old Jun 7, 2008 | 10:08 PM
rival12's Avatar
had the recall done on your ignition switch?
when the contacts go bad, your key/ignition thinks it is in the off position, so it shorts and cuts power.....not sure if that's the case, however, if it is.....when it dies for good....i.e. won't start again, try turning the key between the start and on position, you have to turn it half way......like don't let it turn back to the on position.....
if that's the case hope this helps.....
fyi the ignition switch comes apart (needs to come apart to go in)
Old Jun 8, 2008 | 01:36 PM
Slo_Accord's Avatar
Default Re: (rival12)
what models is the recall for?im guessing its free and is there a mile limit to this recall like the emisions one(150k)? this is great! i love getting free stuff done to my car!
Old Jun 10, 2008 | 07:47 AM
rival12's Avatar
The problem was with 5th Gen Accords (94-97)
Not sure if it is still active, but the recall was for 1997 models. It's an easy fix though.....might take....20-30 mins.
Steering Column Cover Off, Unscrew The Switch.....Remove the clip. Pull it apart, put on the new one
Old Jun 10, 2008 | 08:27 AM
accord99power's Avatar
check alternator
Old Jun 11, 2008 | 07:12 PM
rival12's Avatar
Default Re: car dying (accord99power)
cheapest alternators i found..... HondaDistributors.Net
Old Jun 12, 2008 | 05:07 AM
fubuallstar's Avatar
And also buy an optima battery yellow top well worth it going on 3 years no problems (knock on wood) i have a 2000 watt amp and other minor things running also
Old Jun 12, 2008 | 03:22 PM
rival12's Avatar
Default Re: car dying (fubuallstar)
I got a redtop that's been going strong for three years....i can leave my head lights on for 2 days.....and it doesn't kill the battery....
Didn't mean to hijack thread.
LadyCivic91
Mar 13, 2013 01:01 PM
azndecoy66
Audio / Security / Video
Nov 12, 2008 05:05 AM
CrazyModGSR
Jan 14, 2005 06:12 PM
stasi
Nov 1, 2004 01:34 PM
dannyboi
12
Jan 7, 2003 10:32 PM
