ef b16a vss
Old Jun 1, 2008 | 06:13 PM
ChrisC.'s Avatar
Default ef b16a vss
just wondering if anyone could tell me how to hook up the vehicle speed sensor up in my 90 si i just swapped in a b16a obdo and its just the last thing i have to hook up to get this thing runnin thanks
Old Jun 1, 2008 | 06:22 PM
TRUcrxEr's Avatar
Default Re: ef b16a vss (ChrisC.)
http://cgi.ebay.com/ebaymotors...ZWDVW
i believe this is what u r looking for.
Old Jun 1, 2008 | 06:52 PM
dsnONE's Avatar
he asked how to hook it up, not what it looks like anywho, it bolts in at the rear of the transmission, accessible from the top, and u can find it directly below where the intake piping comes off of the throttle body. so basically get close to the trottle body and look straight down, you should see it, 2 hoses, and 2 bolts..
Old Jun 1, 2008 | 06:59 PM
CRex_22's Avatar
it is a cable right?? if so just plug your stock one in the longer middle hole. it should work fine. thats how mine is. if its electronic then i dunno?? might have to get an eg cluster and wire it in.
Old Jun 1, 2008 | 07:27 PM
ChrisC.'s Avatar
Default Re: ef b16a vss (eda6)
is there a way to wire it into my cluster and ya it is electronic
Old Jun 1, 2008 | 07:29 PM
ChrisC.'s Avatar
i have the jdm engine harness so i could just cut the plug and wire it in somehow is what i was hoping
CRex_22's Avatar
you'll have to wire it in using the plug from a eg harness and get an eg cluster. i don't think it'll work with the ef cluster.
Old Jun 1, 2008 | 07:50 PM
ChrisC.'s Avatar
Default Re: ef b16a vss (CRex_22)
how hard is it to put in the eg cluster and what about the sir cluster for en ef would that work just the same. and am going to have the vss for my vtech to work
Old Jun 1, 2008 | 07:52 PM
CRex_22's Avatar
the sir cluter is a cable also i believe i'll do some research but im pretty sure of it.
Old Jun 1, 2008 | 08:18 PM
ChrisC.'s Avatar
i just thought it would work because it came out of a jdm 91 crx so i figured the sir dash would hook up to it
Old Jun 1, 2008 | 08:24 PM
CRex_22's Avatar
Check the back of this the black circle on the bottom right is where the speedo sensor plugs in.
Old Jun 2, 2008 | 09:53 AM
xalents23's Avatar
The SIR cluster is an electronic cluster not cable.
Old Jun 2, 2008 | 09:58 AM
CRex_22's Avatar
Default Re: (xalents23)
does it depend on the year?? cause I bought a jem b16 and an sir cluster and it was cable??
Old Jun 2, 2008 | 10:09 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xalents23 &raquo;</TD></TR><TR><TD CLASS="quote">The SIR cluster is an electronic cluster not cable.</TD></TR></TABLE>
CRX/EF not SIReg.......
Old Jun 2, 2008 | 11:30 AM
xalents23's Avatar
Default Re: (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
CRX/EF not SIReg....... </TD></TR></TABLE>
I was talking about the ebay one he posted up earlier.
Link: http://cgi.ebay.com/ebaymotors...ZWDVW
Old Jun 2, 2008 | 12:00 PM
CRex_22's Avatar
that is just like the one i bought and the black circle is where the speedo cable plugs in.
Old Oct 6, 2008 | 05:58 PM
Boosted_CRX_507's Avatar
Default Re: (CRex_22)
can i use the stock 91 hf crx vss on my b16 tranny? its a cable tranny
Jason Nucom
Oct 27, 2012 05:29 PM
SmackerS
Feb 23, 2008 04:18 AM
