Where To Start?
my car has been having issues..
it tends to seem like its going to turn off
the RPM drops below 500 sometimes while turning or reversing
even when in idle its at about 500 give or take some..
sometimes below sometimes above
the car feels "tired"
so.. where should i start?
info:
- new (used) motor (5months ago? o.O maybe more)
- recently changed timing belft(1month or 2 ago)
-messed up right arm and things in there (car pulls to the right) from hitting cement thing on freeway (hasn't been an issue yet)
- i got a car stereo
- just changed battery to a blue optima
- i got HIDs
- i got aftermarket foglights
- got rear ended (1yr ago?)
any idea would help...
just throwing it out there... can it be my alternator?
thanks
EDIT: problem becomes HUGE when A/C is on.. it DOES turn off.. but only when making a turn
info:
- i got HIDs
thanks
It would be helpful to those people trying to answer your questions if you would provide the year and model information.
In general, low idle problems can be caused by the IACV, or the screen of the IACV, and build up of contamination around the throttle plate area.
Were you able to check the timing after the new belt was installed?
sorry.... 94 Honda Accord LX sedan
no.. i dont know much about engines..
i just try to figure it out and then tell my dad.
his the mechanic
he double checked the belt
to see what was the problem but nothing there
his the mechanic
Try this link. The pictures are from Integra, but it is very much similar to Honda. I used it to find mine (96 Accord).
http://www.team-integra.net/se...=1174
SlimJim25
Apr 17, 2013 01:09 PM
kevcha711
Jan 29, 2010 08:31 PM
diablo2184
Nov 11, 2005 05:19 AM
sohctodohc
12
Jan 26, 2005 08:04 AM
