Ran fan relay - mine is different
Old Jun 1, 2008 | 01:08 PM
Run Away's Avatar
Default Ran fan relay - mine is different
Alright so all the manuals and pics I have seen show the rad fan relay here:
On the passenger side frame rail sorta.
I don't have anything there, there isn't a relay there, never was from what I can tell.
Mine is located on that bracket behind the headlight with the A/C relays. There are 3 relays there.
http://media.honda.co.uk/car/o...5.pdf
That page shows the three relays being the compressor clutch relay, the condenser fan relay and the A/C diode.
My car had A/C (i removed it). But one of those three relays there controls my rad fan. I can feel it click when i jump the fan switch.
Anyone else's car setup like this? Mine is a canadian car if that makes a difference.
Also, my rad fan gets 5-6V power when the key is on, 12V when the rad fan switch is jumped. Why is this? The motor doesn't run on the 5V.
Shouldn't there be no voltage to the fan unless the rad fan switch is closed?
Old Jun 7, 2008 | 10:12 AM
acmoc's Avatar
Default Re: Ran fan relay - mine is different (Run Away)
ttt
19 crx 89
10
Aug 26, 2010 12:38 PM
xTomei
10
Jun 7, 2010 06:02 PM
littleblue
Oct 14, 2008 04:44 AM
Jonathan_ED3
Sep 27, 2008 10:11 AM
