what should i do with my ls swap?
Old Jun 1, 2008 | 11:33 AM
b17 turbo's Avatar
Default what should i do with my ls swap?
i have a 95 integra four door that got totaled i got the car two years ago ran fine it was all good except its got 260k its starting to smoke it also needs a clutch so i took the swap out because i got a 95 integra 2 door that needs a swap im going to put this in there but before i do id like to rebuild it a little wanted to do an ls vtec but i am thinking that would not be ideal since i should probably spend the money for a clutch and rings possibly. i dont really want to spend a whole lot off money on it . i heard of people putting putting single layer gaskets to give it a little more compression since im going to do rings on it should i put higher compression pistons in it ? is there an oem piston that fits that would give it a little higher comp? would a lightened flywheel maybe be ideal, like i sayed i dont wanna spened to much on it but also want to build something that has a little more power thn stock. any info would be great thank you
Old Jun 1, 2008 | 11:46 AM
0LdsKooL's Avatar
If you notice anything about honda, it's goes like this "you gotta pay, to play" thats what I learned
Old Jun 1, 2008 | 11:59 AM
b17 turbo's Avatar
Default Re: (0LdsKooL)
well yea i understand that
01luda
Dec 23, 2007 06:49 PM
Mixmasta
13
Sep 27, 2007 08:33 PM
chex329
Oct 5, 2005 07:22 PM
gassaversracing
Feb 10, 2005 12:04 PM
DRKSol
Sep 1, 2003 02:36 PM
