HELP WITH REAR CONTROL ARM!!!!!!
Old Jun 1, 2008 | 11:21 AM
naahnaah's Avatar
Default HELP WITH REAR CONTROL ARM!!!!!!
i tried taking out the bolt for the lca (the side by the wheel not the frame) and it broke in half and half of the tread part is stuck inside and im pretty far from my house anyone around hesperia can come help or have a way to take out the bolt?
Modified by naahnaah at 11:40 PM 6/1/2008
Old Jun 1, 2008 | 11:54 AM
naahnaah's Avatar
Default Re: HELP WITH REAR CONTROL ARM!!!!!! (naahnaah)
Old Jun 1, 2008 | 11:59 AM
jdmwannabe813's Avatar
help this guy out
Old Jun 1, 2008 | 12:18 PM
naahnaah's Avatar
Default Re: HELP WITH REAR CONTROL ARM!!!!!! (jdmwannabe813)
no one?
Old Jun 1, 2008 | 12:20 PM
lmike6453's Avatar
well is it stuck in bushing or it actually snapped and part is stuck in shock housing??
Old Jun 1, 2008 | 01:01 PM
naahnaah's Avatar
Default Re: (lmike6453)
is in the bushing
Modified by naahnaah at 2:37 PM 6/1/2008
Old Jun 1, 2008 | 01:23 PM
lstek's Avatar
ur best bet is to take a grinder and cut the nut on the back of the lca off. then reinstall with a new nut and bolt.
Old Jun 1, 2008 | 01:39 PM
naahnaah's Avatar
Default Re: HELP WITH REAR CONTROL ARM!!!!!! (lstek)
cut the pointy end? is still stuck on the lca and the other thing?
Old Jun 1, 2008 | 03:50 PM
lmike6453's Avatar
i had this problem twice-pay attention if it's the one that goes into the shock housing...
you don't want to ruin the shock housing but you have to loosen the bolt's thread which will bend the shock housing outward from the lca, do as much as needed to be able to see the bolt between the lca and shock housing and dremel the bolt off...
it sucks i know but do not drive your car until you get this fixed
when you dremel off the bolt it's still going to be stuck in the lca and can be removed but it's a pain which is why i bought omnipower lcas...they have an allen screw holding the bushing in the lca so it doesnt spin in the future when trying to lossen the "frozen" bolt out of it
Old Jun 1, 2008 | 05:50 PM
naahnaah's Avatar
okay thx
MrToxygen
Apr 27, 2010 06:11 PM
CRXguy_88
Mar 11, 2010 10:39 AM
slo_hatch
Oct 14, 2008 07:48 PM
FuLlRaCe XLR8R
Suspension & Brakes
Feb 27, 2007 11:33 PM
ophdehEEzY
Sep 8, 2003 04:53 PM
